Mt57 prop hub bearing
MN
After pulling my prop hub to check the bearing I noticed it is snug in the housing but I CAN rotate with my finger. Is that something that will snug with engine temp or should I snug it up with something. The motor does vibrate alot at full RPM Lanny Khelsea
MN
RE: Mt57 prop hub bearing
Rich, Thanks for the answer. Could you shed any light on the high amount of vibration? The prop shaft vibrates left and right a good 1/4 in at 6500. Other than that it sure is a powerhouse. Lanny
