Throttle Linkage on 3W Tilotson
Old 04-11-2002 | 04:23 PM
My Feedback: (62)
Default Throttle Linkage on 3W Tilotson
What are you guys using on your throttle arm hookups? My new engine just has a short little arm with a pretty good size hole in it.
Are there any websites or pictures out there? It has the spring set up and is a model HS232. Thanks_Bob
Old 04-11-2002 | 11:37 PM
Bob
Leave the spring on, just nip the ends off with cutting pliers. Its left there for a vibration damper. The arm you can make one from a bellcrank arm or solder on a metal tab of appropriate length and drill a small hole in it.
Old 04-12-2002 | 07:37 AM
My Feedback: (62)
Default Thanks
I was unaware that a small arm was needed since the carb on my 80 is set up differently. It must be an older model. It's an HS203E and it has a shaft where a steerable nose gear type of arm is bolted on. Thanks for the info_bob
