help on starting
Old 01-29-2011 | 10:39 AM
Default help on starting
hi got a 26 evolution petrol start easy on starter but hand starting is so hard it will not fire am i doing any thing wrong put choke on prime it turn it over but will not fire put the starter on and it start
Old 01-29-2011 | 11:31 AM
w8ye's Avatar
My Feedback: (16)
Default RE: help on starting
You may have the low speed mixture screw a little bit lean
Adjust the low speed screw to where you get a good transition to high speed
Old 01-29-2011 | 11:35 AM
ALIGN STARTER FOR AERO ENGINES is it any good they say it will start up a 50cc gas engine has any one used one as my starter is not powerfull
Old 01-29-2011 | 11:38 AM
w8ye's Avatar
My Feedback: (16)
The Align starter is mighty expensive
A good battery is just as important
Old 01-29-2011 | 12:11 PM
i need to screw it out is this right
Old 01-29-2011 | 12:14 PM
w8ye's Avatar
My Feedback: (16)
yes, just a very small amount
Old 01-29-2011 | 03:03 PM
And get the carb hissing wet before you try to start. Once fuel is in there, these engines are first flip starters.
Old 01-30-2011 | 04:19 AM
just had cowl off went to start bye hand fuel was only coming 1/2 way in pipe so thats why i good not start bye hand but starter wood my tank sits low put some padding on so it sit higher ajust low end 1/4 turn richer two flicks bye hand it started a big thank you for your help no need for elec starter now
Old 01-31-2011 | 01:20 PM
i am getting oil spots under the plane so have i riched the low end two much or is this right to se oil spots
Old 01-31-2011 | 01:57 PM
w8ye's Avatar
My Feedback: (16)
I would not draw any conclusions about fuel mixture from oil spots under the plane.
There are too many other variables.
