prop size question
My Feedback: (212)
NC
Went out today to enjoy some beautiful eastern North carolina weather and fly the Wildhare Edge 540 that I just got with a TOC-53 gas engine on it. The guy I bought it from had a Evolution 24x10 prop on it.The engine has an MTW canister and starts and runs like a dream. It will tick over at an unreal low idle but once in the air, I just couldn't get any good rpm's out of it.It was just too much prop for the engine. I know that the prop is too large for this engine, I just need to know what prop is best for this engine and IMAC style flying. Thanks for the help.
The 3mm 53 turns slighly less RPM that the average 50 but it has a little more torque. I would not use anything larger than a 23" prop, and the Evolution prolly isn't the best cut for the engine. So a 23-8 in another brand if you are looking for peak rpm. A 22-8 would probably be better still. I'll suggest a laminated wood Xoar as a good start.
My Feedback: (212)
NC
I just found a new Menz 22x10 in my shop.Where is the best place to buy a drill guide for the TOC-53? Also, what do you guys think about the Menz? Thanks
