RPM drop in bank turn?
FL
I’m running a DLE 30 and for some reason when I'm flying strait and level with no change in throttle input, when the plane makes a bank turn the rpm drops. Its more than just a little if I had to guess I’d say 700 rpm or so. It doesn’t sound like its leaning out, sounds more like richening if anything.
VA
RE: RPM drop in bank turn?
If this DLE-30 has a sided-mounted carb (instead of the current version rear-mounted carb) most likely you are hearing the effects of centrifugal force causing fuel to move in the opposite direction of the turn.
Lean out the high needle very slightly. It probably is the fuel regulating membrane and fuel weight pushing on the lever. A negative-G bank turn probably does the opposite and leans out the engine slightly. In a well tuned engine, both the slight richening or slight leaning out should have not much influence on engine running.
Remember that you make a turn increasing AOA with elevator while banking.
I am not saying that is what happens in your case, but for tight turns, that higher AOA creates more drag in the plane.
The sound variation may be like during a vertical climb, where the rpm's slow down, trying to find the regime for higher torque of the engine.
As stated above, it is more noticeable for props with high pitch.
