Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Best side dump muffler for a 20cc engine >
Old 02-15-2011 | 07:43 AM
Default Best side dump muffler for a 20cc engine
After having played around with a few after market side dump mufflers on my little G20 engine, I am of the opinion that most do not have enough volume to allow for very effective exhausting of the engine. In your opinion, which of the currently available S/D mufflers does the best job regarding increasing engine performance.
Karol
Old 02-15-2011 | 08:02 AM
w8ye's Avatar
My Feedback: (16)
Default RE: Best side dump muffler for a 20cc engine
This one
http://www.horizonhobby.com/Products...=ZEN848EW015A0
Old 02-15-2011 | 11:29 AM
Rcpilot's Avatar
My Feedback: (78)
I'm not sure that I agree with the notion that the stock muffler is the "best" at "effective exhausting" for this motor.
Bisson makes a wrap around pitts, but you asked for a side dump.
Slimline doesn't even list a muffler.
So maybe the stock muffler is the "only" muffler available right now. But does that really make it the "best"? [sm=spinnyeyes.gif]
Side dumps aren't really going to do much for performance anyway. They are just a diverter to keep the exhaust off the plane. If you want performance out of a side dump, it would have to be pretty darn big and have some mighty special baffles inside.
Old 02-15-2011 | 11:39 AM
w8ye's Avatar
My Feedback: (16)
Milton sells one
http://www.rcextremepower.net/mufflers.html
Dick Bennett sells one
http://www.bennettbuilt.com/page3.htm
JTEC sells two kinds
http://www.jtecrc.com/profile_sidemount_mufflers.htm
http://www.jtecrc.com/sidemountmufflersgas.htm
Old 02-15-2011 | 12:37 PM
scooterinvegas's Avatar
I have a BH Hanson pipe on my Zenoah, works great!
Holy Crap the pic is big.. sorry.
Old 02-15-2011 | 01:05 PM
I have tried the stock muffler, and side dumps from Abell, Bennett's, SPE and even tried a Mac's header pipe with a mousse can muffler which gives a real performance boost but is extremely noisy. So far the Bisson side dump for the G23/G26 with 16 cu. ins of volume versus between 5-8 cu. ins for the rest, and which has the same mounting dimensions as the G20 seems like it could be a very good choice. Has anyone had any experience using this muffler??
Karol
Old 02-15-2011 | 01:26 PM
My Feedback: (19)
ORIGINAL: karolh
Karol
I have not used the Bisson side dump muffler on a small Zenoah, but have used them on a Brison 2.4 and other engines. Worked very well with an acceptable noise level if you don't cut the exhaust stack too much, if at all. They seem quieter than a Pitts type muffler but get louder with every bit you cut off the stack.
Old 02-15-2011 | 02:43 PM
B&B (Bennett) will be the cheapest, but not exactly what I'd call a muffler, more like a manifold, but they do work.
Old 02-15-2011 | 07:39 PM
Whistling Death's Avatar
A bowman ring might give it a little boost too.
I am planning on trying one out in my G20 to see what it will do.
Old 02-16-2011 | 08:08 AM
I just got a ring from Frank which I plan on trying, mostly out of curiosity just to see what if any increase it will give. Have used his rings before in glow engines and the increase in compression was quite noticeable.
Karol
Old 02-16-2011 | 08:10 AM
Oops.....double post [:@]
Old 02-18-2011 | 07:35 AM
flygilmore's Avatar
I have the Bennett header pipe on my G20....the one thats angled back about 15* (single pipe). I like it because it is very, very small, very light and although it is loud, it is a deff. increase in power over the stock black can (stocker).
If I ever put it on a plane that will allow, I will be putting a Macs header on and building my own mousse can pipe for it!!!
Old 02-18-2011 | 11:59 AM
I used a Mac's header pipe for the G23/G26 to make a mousse can muffler arrangement for my G20, and though it was quite noisy the max. revs increased by 900 rpm.
Karol
