IBEC or Remote Kill Switch or nothing ?
Hi,
I am in the middle of my first gas airplane setup. now i am consider the following options :
1) IBEC + dual batteries and switchs. ( currently i am using dual nicd batteries and switchs on my glow airplanes )
2) Dual batteries for rx + separate battery for ignition + Remote Kill Switch
the IBEC connects to the rx through fiber optic cable but some pepole says that there is still good chance of RFI interferences.
what about remote kill switch ? it's also connects to the rx through fiber optic cable is that means it will also have the same chance of RFI interferences ?
i do my best to make it intersting....
the radio is sanwa rds8000 2.4gb, and the engine is 30cc sap-180
what i am trying to figure out is whether there is any difference in terms of RFI interferences generation between those two components
I have switched some of my warbirds over to one (1) 5000MA Lipo this year and have been test flying this without any problems at all.
If there was any doubt with my baby's well being I would,'t be useing them.
I didn't want to have two different styles batteries (ni-cad/lipo) in the same plane for radio and engine power.
There is a bunch of guys around here with Smartflys that never have any problem doing the same thing.
http://www.tech-aero.net/ultra-ibec
Jim
Jim
the reason i am asking that is that although i am far from being RF expert it seems to me that pepole are more tolerant to optical kill switch then IBEC
the question is if it has some logical reason ?
ORIGINAL: selnekav
Jim
My Feedback: (8)
It's not a question of tolerance.
They are two different devices. The IBEC (Ignition Battery Eliminator Circuit) is what the name implies. It has optical coupling and ignition kill capability. My TechAero IBEC has a built in regulator to reduce Lithium battery voltages to 5.0 volts. It is rock solid. There is no question of RFI. The opti kill has one function only - remote shutoff of the ignition.
So the answer to your question should be obvious. If you are going to continue to run a separate ignition battery, forget the IBEC and get a smart fly opti kill.
