quadra 65 or 75?
IA
quadra 65 or 75?
I have what i believe is a quadra 75 engine that i picked up second hand and i was wondering if anybody knows if there is a way to tell a 65 from a 75 without disassembling the engine? There is what appeares to be a serial number scribed on the case if that helps.
mike
mike
DC
RE: quadra 65 or 75?
The 65 was pretty rare and was made a long time ago....I THINK all the 65s were made using the chainsaw crankcase..I still have one around here someplace, maybe the cylinder has a casting number on it...Will look...
NC
I believe the 65's were magneto with spring starters and the 75's were electronic ignition. The 65's are heavy and great if you need nose weight, but the 75's are more piowerful.
My Feedback: (19)
ORIGINAL: STUKA BARRY
The few 65s I have seen all had the cut away, saw crankcase and looked to be heavier than the 75 but I'm not sure about the weight though.
IA
Thanks for the help guys, From your discriptions it sounds like a Q75. My engine has a round crankcase with a backplate attached, spring starter and magneto ignition. The engine power apeares to be a little soft compared to some modern gas engines of this size but it starts everytime on the first flip and has a rather smooth idle compared to higher power engines. I have a custom muffler that i tig welded that works well and I am getting around 7800 rpm on a 22-10 prop currently and think i might try a 24-10 by your suggestions.
mike
mike
