jc 28 v2 pitts
jc 28 v2 pitts
hello. i bourght a pitts style muffler for my jc 28 fitted it an flew it, it was noticeably slower than the standard one, i put the taco on it and i lost 800rpm is this normal with pitts mufflers ?? i
RE: jc 28 v2 pitts
I'd stop with the trouble shooting and deep investigation and just get rid of the muffler. RPM loss (or gain) is dependant on engine AND muffler design.
BTW, what kind of taco did you put on the engine, and did the engine find it tasty? Perhaps you meant tachometer?
RE: jc 28 v2 pitts
ok, taco over here in the uk is short for tachometer i dont even no is there is a source called taco? anyway back to the question,why is my pitt muffler lossing so much rpm im useing an inline taco that plugs straight into the ignition?are all pitts mufflers like this or have i got a faulty one????? if i go and buy another pitts will it loss about the same rpm?
RE: jc 28 v2 pitts
A Pitts muffler, or any other, should never, ever, rob an engine of 1/10 of it's RPM output. It would be considered in the ballpark to experience 100-200 rpm loss or gain. Do you have a bad one? hard to say because all the mufflers of that configuration may do the same thing, in which case yours would be right in line with the rest of them.
Either way you only have two options. Keep it and deal with the loss of performance or get rid of it for something that works better. You will not be able to fix what you have unless, and that's a very slim unless, you can hog out or modify the muffler components that cause the power loss. Port matching, exit pipe diameter, spark arrestor, exit pipe baffling, muffler volume, are all suspect. This was the reasoning behind my earlier post about trouble shooting.
Dump the junk.
Dump the junk.
RE: jc 28 v2 pitts
hi, standard and pitts were both tuned to the maximum i could get 8500 with the standard 7700 with the pitts, both within an hour of each other same oil fuel prop etc, would cutting the pipes down make that much difference ?
