Da 85 or zdz 90
My Feedback: (66)
RE: Da 85 or zdz 90
TOM could either one of those be modified to work? If the cylinder bolt holes match then could the cylinder be turned and the ports matched up? Also if the rings are pinned could the rings pins be relocated also? I would prefer a rear exhaust set up but if I have no choice then a wrap around header will have to do.
My Feedback: (66)
RE: Da 85 or zdz 90
ORIGINAL: Whistling Death
Wow
Wow
TOM thanks for your replys.
TOM do you know of any single cylinder engines in this size range that i can make into rear exhaust or one that comes that way?
My Feedback: (13)
MN
RE: Da 85 or zdz 90
ORIGINAL: airraptor
I will be building a speed project. Can either one of these engines have the cylinder turned so that the exhaust is out the rear? If not any other singe cylinder engines around this size be able to? Looking to run a 18x20 - 20x18 prop.
If there is, send me a PM with the company,,, I would like to try one out..
as far as i know,, Menz makes the most agressive props
RE: Da 85 or zdz 90
Some specialized manufacturers do make extremly high pitched props. Some can be special ordered in quantity.
I cannot think of any gas engine offhand that has an aft facing exhaust port. All are on one side or the other, and when combined with ring pin stops, eliminates any possibility of rotating 90 degrees. That doesn't begin to factor case to cylinder port matching.
RE: Da 85 or zdz 90
ZDZ 40 RE is the only rear exhaust that I know of, it won't swing those props. Rick
http://www.troybuiltmodels.com/items/ZDZ40RE.html
