OS GT33 33cc gasser
#203
RE: OS GT33 33cc gasser
Guys, I got a bit of advice from OS today. You can retard the timing just a bit by adjusting the sensor 1mm counter-clockwise (viewed facing the prop hub face). This should improve hand starting. As has already been mentioned, about 1/8 or a little less throttle is also the best throttle position for starting.
O.S. is extremely safety conscience. This is one of the reasons for having the CDI not fire until a certain rpm is seen.
Steve
Steve
#205
ON, CANADA
Has anyone used a Tru-Turn spinner with this engine. The spinner I have uses a spacer to fit the crank diameter (9.5 mm down to 8 mm, I think).
Problem is that the engine's drive hub is hollowed out behind the drive plate. It's possible that the spacer could vibrate backwards into this cavity.
I was thinking of using the locktight for bearings or maybe CA to glue the spacer to the spinner. Any thoughts? Another thought was using a spacer tube behind the drive plate, same as the one needed for the wood props (10 mm OD, 8 mm ID). I found an old stab tube (from a H9 27% Extra 260) that works well for a prop hole sleeve.
#207
You can't go wrong with a DLE, I have 3 30's and each is a great engine, but I will be trying one of these in a Sbach. But to tell you how much I trush the DLE i have one in a ESM Mustang. They do not float with dead sticks and need reliable engines. Planes weights 15+ pounds and the DLE pulls it easy!
ORIGINAL: ameyam
Hey, any further user opinions? I really need to select between this and the DLE30 next week
Ameyam
Ameyam
#210
So, a final word would be that the OS33 is as good or better than the DLE30? I need to decide NOW if I am to purchase it in Singapore next week
Ameyam
Ameyam
#211
ORIGINAL: swk550
I recently ran my OS GT33 for the first time. I am using a home made isolator mount. It can idle around 1800 RPM but my mount shakes too much. I get a good reliable idle at 2300 RPM. I tested two props on the standard muffler. I got 7800 RPM with my 17-12 pattern prop. I am getting 7200 RPM with a Xoar 18-10 swoard. I too had to start at 1/4 throttle to keep it from running backwards. The engine is very easy to start. Attached are some photos of my set-up.
Anyway, the sucker runs again so tuning is no big deal
#212
ORIGINAL: ameyam
Ameyam
Ameyam
#213
My Feedback: (14)
Matt, You are at a slightly different elevation, running a different prop and tuned pipe. Your needle settings will be different than running the stock muffler. If for some reason your tuned pipe setup isn't timed right it will be stuffing exhaust back in and will run lean and over heat. Could be header length, convergent cone location, stinger length etc. Different engine exhaust port timing requires different pipe timing as does going from glow to gas. Heat and flame spread also effect tuned systems.
Too bad you don't run it with the factory tested exhaust to simply see how it acts, could be it doesn't like your setup. I had the OS 160FX on a Jett incowl turbo muffler. Gained 1000 rpm on a Bolly 18X10 carbon but never landed with the engine running. Tried richening the high, the richening the low, leaning the low and all possible combinations. Ran great on the ground but would either blow the plug (lean) or just quit in the air. The engine had baffles all around it and 1 to 4 air in to out. Ran perfect on both a Jtec Dual snuffler and a Bisson ST4500 pitts.
Of course if it runs fine now that it's back, Hobby Services fixed something but the world may never know. If it tunes like the 160fx it will never run correctly if the low needle is lean.
_____________________________
#214
ORIGINAL: ameyam
Ameyam
Ameyam
#215
ORIGINAL: captinjohn
A real good thing to remember is the DLE 30cc engine is easy to find parts for and very low priced. Price the parts for a OS engine and a DLE engine. I bet you will get the DLE[img][/img] Capt,n
ORIGINAL: ameyam
Ameyam
Ameyam
Compare ignition module price only.
On the GT 55, the price of ignition is 279 USD (add 49USD for the sensor)
Best regards
#216
My Feedback: (14)
ORIGINAL: mpascual
+1
Best regards
ORIGINAL: ameyam
Ameyam
Ameyam
Best regards
Very good point! Tower/OS needs to rethink the parts pricing....but they won't.
#217
That's a good point. Lots like to point out OS reliability/durability, which hasn't been entirely proven on this 33, but if you wreck a plane and break nothing more than an ignition box, it'd cost you almost a new DLE to put it back into service....ouch! I wrecked my DLE55/Reactor combo 2 years ago (due to my stupidity), and the ignition box looked ruined. Sent it back to Valley View (where I bought it) and they fixed it up quickly and for relatively little, stating the ignition worked fine. It finally failed a year later (developed a miss then quit), but I can't blame that on the ignition. A new cylinder, cases, and bearings for the DLE55 cost me less in repair than the OS ignition...
#218
ORIGINAL: mpascual
Best regards
Best regards
The recently returned 33GT is being run with a standard RCexl CDI. This costs around 55$
#220
My Feedback: (14)
ORIGINAL: MTK
#221
ORIGINAL: ghoffman
So, Matt,what happened with Hobby ''Services''?
Nothing else. They simply returned the engine after 5 1/2 weeks, replacing the backplate (with the mounting lugs). They told be in a phone conversation that the backplate was broken which supports the extremely lean running I experienced at the very end. They did not return the part for my inspection. But they also said that they ran the engine when they first received it with the broken backplate and that it ran fine....I don't believe that
I just hope the backplate was simply a bad casting and not a design flaw. My application uses a soft mount so the backplate load is far lower than in a hard mounted set-up. Nevertheless, somehow the backplate was broken in what they claimed was shipping damage. I tend to believe that if there indeed was a broken backplate, my set-up experienced it first because the one time we did start the engine with a starter, it ran extremely lean with no power. So the alleged damage may have happened during the second flight I took with the engine
I don't know really, it kinda smells a bit fishy.......however I can't argue with the good result so far. The engine runs well, on pipe, same as the first couple runs I had on it. Spools the 18x12 at very nice output, far better than any other engine in this class I have played with (SAP30, Mintor 38 and ZDZ40). I also have run a 20x10 on this engine and it turns that size prop fine but again, it's piped.
#222
ORIGINAL: PlaneKrazee
Did you check and set the timing @ 28 degrees BTC for the RCEXL module?
#224
I checked with Rotor, they dont have either engine.
Any other place in Singapore I can look for these?
Ameyam
