rcexl optical switch
Old 06-25-2011 | 12:53 PM
Default rcexl optical switch
Buddy cant get to work with DX7 on the gear switch? Help please
Old 06-25-2011 | 01:38 PM
BarracudaHockey's Avatar
Default RE: rcexl optical switch
Use the monitor screen and see if the switch is controlling the channel he wants.
Its not very complicated, the two red leds go inline between the battery and ignition, and the other wire plugs into whatever channel your going to use.
Old 06-25-2011 | 02:17 PM
Also check and make sure the channel you are using is set for full travel in both directions.
Milton
Old 06-25-2011 | 03:01 PM
Milton, sending you a PM.
Karol
