Question for the Walbro/Zenoah Experts
I have used the WT-338 carb from my Zenoah 38 for a bit of experimentation on another engine and need to purchase a new one for the Zenoah. I could purchase another WT-338. But there is also the WT805 as used on the MLD35 and there are some WT 542's for sale on the well known auction site at relatively low prices. These are all 13.5mm venturi twin needle carbs.
So my dilemma is about which of these to buy as apart from general dimensions, throat and venturi size etc. I don't know enough about Walbro carbs to be able to tell from the part numbers whether they will have similar running characteristics due to jet sizes, metering spring and so on.
Thanks in advance.
MSS.
Thanks in advance.
MSS.
RE: Question for the Walbro/Zenoah Experts
13.5mm carbs Abstract from my database:
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type"><title></title> <caption>compiled data</caption> <thead>
</meta>
carb | dia | HP | set | use | run | remark | date | |
WT201 B | 13.4 | 0 | D20-WAT | 0 | MVVS43, DA50, for better fuel flow use: wt 465A, wt 76 I think, wt257 | |||
WT484 | 13.4 | 0 | 0 | |||||
WT561 | 13.49 | 0 | D20-WAT | 2 | mvvs35cc, main jet 1mm, K20-WAT | |||
WT540 | 13.49 | 0 | 0 | has acceleration pump!!! | ||||
WT170 | 13.49 | 0 | 0 | |||||
WT338 | 13.5 | 0 | 0 | zenoah 38 | ||||
WT664 | 13.5 | 0 | 0 | WT-664 has a wetter midrange, use WT918 instead | ||||
WT918 | 13.5 | 0 | 0 | Solves many problems in 50cc engines (Jody valleyview) | ||||
WT610 | 13.5 | 0 | 0 | main jet 1.2mm (obsolete carb) | ||||
13.5 | 0 | 0 | ||||||
WT465A | 13.5 | 0 | D20-WAT | mvvs, DA | 0 | better fuel flow than WT201 (info Pat Roy) |
</meta>
Antique & Pe.....both first class data from people that know this stuff. Thanks....I know it takes time for you guys to share data. Best Regards Capt,n
Funny, this thread came along when I was about to experiment with a carb from a DLE 30 on my G38.
The WT-338 seems to be such a pain in the butt to tune so I figured I'd try one from a DLE 30.
ORIGINAL: Whistling Death
The WT-338 seem to be such a pain in the butt to tune I figured I'd try on from DLE 30.
ORIGINAL: captinjohn
Ok...it looks like you said I will try a carb off my DLE30 on the G38....right?
Pe and Ralph,
Thank you for your really helpful responses and your wilingness to share the depth of information/experience. Fully support Captinjohn's comments. Much appreciated.
For anyone following this tread, according to another thread the WT 542 has an accelerator pump.
http://www.rcuniverse.com/forum/m_96..._1/key_/tm.htm
Regards,
Maninder.
Regards,
Maninder.
