SV26 Gas Engine Issues
Old 07-16-2011 | 09:04 AM
Default SV26 Gas Engine Issues
OK - so I re-tuned the 26cc Gasser (SV) and it no longer dies when the throttle is cut back to idle at the top of a hammerhead.
But, it now pops and sputters - but only when flying upright and level.
When I fly it inverted or in a knife edge - the motor runs and sounds GREAT.
Any ideas on why it is popping when gurgling when flying level?
Old 07-16-2011 | 09:29 AM
My Feedback: (8)
Default RE: SV26 Gas Engine Issues
sound like running rich on hi side
Old 07-16-2011 | 12:38 PM
My Feedback: (110)
ditto.........try leaning it out on top end alittle at a time. and see what happens. maybe 1/8 of a turn at a time, but don't go to much or you'll get her to lean. punch her full on the ground each time and make sure it transitions good, before taking her up.............GOOD LUCK........RON
Old 07-16-2011 | 01:01 PM
I don't know guys - It seems like we peaked it out already - but, its worth a try.
Why would it run great inverted and in a knife edge but pop while flying level if it is too rich on the high end? I don't understand the difference - can someone explain the difference to me?
Old 07-16-2011 | 02:07 PM
w8ye's Avatar
My Feedback: (16)
One point brought forth is that you just move the needle a very small amount at a time and then see what happens.
Just a little tweak. One notch.
Old 07-16-2011 | 06:03 PM
soarrich's Avatar
My Feedback: (98)
ORIGINAL: pulcastro
....Any ideas on why it is popping when gurgling when flying level?
Have you tried putting a carb static vent tube to inside the fuse.
