Zenoah G260PUM will not start.
I'm stumped here. My G260PUM (the 26cc boat motor) will not start. It has spark (strong enough to see outside in the sun) and the plug is wet with fuel. I even dripped some gas into the combustion chamber, nothing. I find it hard to believe that with air, gas and fuel it will not even pop. I'm using a 32:1 mix, just like is called for.
Any tips? Could the timing be off? I do not know the history of this motor, other than that I was told it was running not long ago (likely bullsh*t at this point). Thanks!
RE: Zenoah G260PUM will not start.
Probably flooded. Disconnect the fuel line, leave the spark plug out, and spin it over to clear the flood. Then clean and dry the plug and re-install it, hook up the fuel line, and try to start it with no choke. If after a while it still won't start, check the plug again. If it is wet, you probably have a carburetor problem.
AV8TOR
AV8TOR
My Feedback: (16)
I experienced this with a Homelite 25 weed whacker a couple weeks ago and the bottom line is that the muffler was plugged by a blue wasp nest (mud Dauber).
Knocked the nest loose with a screw driver and the engine ran fine.
A guy gave it to me because he couldn't get it to run several years ago and I just got around to looking at it.
Hi guys.
It is not flooded. Also, there are no obstructions anywhere. I had the carb apart and no signs of anything wrong. Spark is strong and blue. Fuel is getting into the combustion chamber. This is really boggling me. Spark+fuel=combustion...or so I thought.
Could the timing be that far off as to not even pop?
DC
The rotor is on a taper, unscrew the starter nut and pull it with a small 2 jaw puller..
Put some rope in the spark plug hole to keep thepiston from moving...The factory piston stopper is a 10mm aluminum piece that screws into the spark plug hole.... A 10mm bolt will do the same thing....
DC
Piece of 3/8 steel about an inch wide...Drill a hole in the middle for a 3/8=24 bolt, 2 holes to put 8mm bolts in the
8mm threaded holes in the rotor...
Been using mine for 24 years...
I'm trying to get it going on my own, even though I am about to step on this boat. There are only so many reasons why it won't run...but this is a real mystery to me.
1) Bright blue spark
2) Getting fuel (even dripped fuel into combustion chamber, not even a pop)
3) New plug
4) Key not sheared
5) Good compression
6) Good fuel
I took the motor apart and there is some scoring on the sides of the piston, mainly on the skirt. Maybe this motor was run without oil in the fuel at some point, I have no way of knowing. Otherwise the motor looks nearly new. There is no play in the bottom end and the piston ring is free. The EI is not adjustable, so that isn't the problem. The carb was completely disassembled and nothing seemed out of place.
3) New plug
4) Key not sheared
5) Good compression
6) Good fuel
Try a small shot of engine starting fluid in carb throat. See what that does. Also I do not know how you are starting it....but it may need to be spun a little faster to start...the way its tuned. Capt,n
I don't see what a shot of starting fluid would do that gas in the combustion chamber wouldn't... Something is wrong here.
The motor is a pull-start and there really isn't a way to get an electric starter on it.
Made another attempt, still nothing. With the plug out, I can see the mist of fuel come out of the C.C. with a flashlight. Is there some condition where the plug will spark when held against the head but not when installed?
Tried again, this time putting some nitro in the chamber. Nothing. Not even a hint of combustion. If anyone is in the Caldwell area, you may very well see an 1/8 scale Miss Bud on the curb tonight.
i'm also using zenoah g26 for my airplane....once i had a problem starting it..I checked the curb., fuel line, timing, etc.....I found out that the E.I. wire had a small cut in which it did not work or gives out current to fire the spark plug.... I fixed the problem by soldering the wire and until now i have not encountered the same problem again.... Try to check you E.I. if it gives current to your spark plug.
Check the compression. It should be at least 60 psi to run. (Hopefully it is much higher.)
I still say it is flooded. Try what I said in my first post. Take out the plug, unhook the gas line, and spin the engine over. Clean/dry the plug, replace it, and try starting it without the fuel line hooked up. I have had severely flooded two strokes take a BUNCH of pulls on the rope with the throttle open and the fuel off to clear out a flood, even after spinning them over with the plug out to clear the flood. I have had malfunctioning carbs completely flood the engine in two pulls of the rope....
AV8TOR
AV8TOR
My Feedback: (7)
ORIGINAL: Sessholvlaru
How does the mag rotor come off? I'm looking at it right now...
I had a similar problem with a fox 4.2 recently. I have just one question though. Is fuel coming out of the carb at all? The reason why I ask that is because I had junk in the carb needles. I actually had to pull the needles out and blow them out with air. I also had to blow air through the port that meters the fuel going into the carb. It sounds crazy but try it. Also, try starting the engine at full throttle. May sound like a bad idea but I had to do the same thing to my 4.2, that how I found out there was stuff in the carb. It would run at full throttle but then die at anything below that. One more thing, check that the diaphram and everything is installed correctly. If it is backwards or the carb is put on backwards that would cause this same problem. Just check to make sure. I have made silly mistakes like that and had the same problems.
ORIGINAL: av8tor1977
AV8TOR
AV8TOR
