My Dream Gas Motor, A Twin DLE 40cc
My Feedback: (34)
Ok, I just have to ask,
DO you ever think we will see a twin DLE 40 down the road?
I love my DLE 20, 30 and 55.
But I would love a small DLE 40 twin. As all the other Twins are way to big and strong for the lower end war birds and scale cubs.
Most of my boys agree a DLE 40 would be a ticked for most war birds, but if it was a twin it would sell like little hot cakes.
Is there a way to make 2 DLE 20's into a twin?
What you guys think?
DC
RE: My Dream Gas Motor, A Twin DLE 40cc
All it takes is money, how much would you pay ??
2 DLE cranks to make into 1, 2 pistons, cylinders, 1CNC crankcase, a larger reed than a 20 uses, Walbro WT76 carb, RC EXL twin ignition...
Bergen helicopters use an opposed 8 hp 52cc twin made from 2 G26s....Don't know if they sell the engine separately....
I doubt they will ever make a 40cc twin but the logical thing to do is for them to make a 40cc single then naturally an 80cc twin could follow.
I have a couple of planes that the 30cc is too small and the 55cc is too big and a 40cc would fit the bill. An 80cc twin would fit quite nicely between the 55cc and the 111cc.
ORIGINAL: Antique
Sending you a PM.
Karol
IL
ORIGINAL: Antique
Found this. I guess the engine can be bought separately.
Joe
http://cgi.ebay.com/Bergen-TWIN-99-T...-/330585163781
My Feedback: (34)
Thanks guys I know it was just a dream, i know twins have there down sides, More weight, takes more ducting to keep cool, etc.. But they just look cool
I would have not give this motor a second thought but its just to wide. I wanted this for a ESM Corsair, or even my 30cc GeeBee R3 but Im limmited to 9in max in with and this baby comes in at 9 1/2 with the plugs.
http://www.hobbyking.co[img]catalog/imageNA.gif[/img]m/hobbyking/store/__11973__5_5HP_53cc_Twin_Cylinder_Gas_Engine_.html
My Feedback: (66)
why not run smaller plugs like the ones for Saitos and put the smaller plug wires on?
ORIGINAL: mikes68charger
http://www.hobbyking.co[img]catalog/...s_Engine_.html
Valley View RC has the answer.
http://www.valleyviewrc.com/estore/v...as-engine.html
What a sweetheart of a engine!
Best regards
Only problem with the VV engine is even with the smaller plugs, which can have other issues, they are 7 7/8" that is offset from the center on the engine. I was really thinking of pulling the trigger on this one for my ESM 74" Corsair. I have a G-38 in it right now and while it is ok in power I know a good 40 twin would put that plane over the top. But with the 7 7/8" width below the center it will stick out on both sides.
Hi Guys
I just purchased my first gasoline powered engine. Its the DLE 40 CC twin cylinder. Mounted it onto a test bench and it is running very well. Now I need to build a model for it.
Regards
Craig
Regards
Craig
My Feedback: (16)
I bet it clears away the sawdust from that jigsaw.
What size prop are you running?
I have one on a sig rascal. Running a 20x6, need 20x8. It will torque roll the rascal, awesome sight.
Hi slowpoke
If I started it in that position,it would clear the sawdust around the jigsaw for sure. I am running the Master Airscrew wood series 20" X 8" prop and ran it up to 6000 Rpm,with more to go,but the engine has less than 15 minutes running time on it. So I am very careful at this stage.
Regards
Craig
Regards
Craig
