Filling the tank.
Filling the tank.
I'm relatively new to gas planes and have a question about filling the tank.
I see lots of pictures of two line tanks with a clunk line that has a 'T' piece for filling from the carb feed line.
Wouldn't filling the tank through the carb feed line have potential to introduce contaminants on the wrong side of the clunk filter?
RE: Filling the tank.
you can use a 2 line set up just make sure you dont fill into an inline fuel filter, as that can cause what you just mentioned...... fill straignt into the tank, and the inline fuel filter should be on the other side of the tee
im not sure i explained it clearly
A three line system is really better. One uninterrupted line with a clunk filter to the carb from the tank. One vent, and one dedicated fill/empty line, which is plugged off after use. The fill/empty line must either be at the bottom of the tank, or have a clunk line on it too to actually be used to empty the tank.
A two line system used properly works ok, but you often introduce air into the system when fueling, and that can cause hard starting sometimes.
AV8TOR
AV8TOR
IMO an inline filter unless of the ultra fine screen variety is pretty much a waste of time in a gasser, and only provides an opportunity to introduce air into the feed line to the carb. I use a three line system and have a felt filter on my fuel jug's pick up line, a small paper element filter in the feed line from the jug and a felt filtered clunk in the tank, which keeps my carb screen very clean. Just my .02 cents.
Karol
Karol
My Feedback: (16)
I decided to put a tee in the clunk line of a gasser and after filling the tank, I plugged the fill line with a wooden dowel.
The engine would not suck fuel? Eventually, I found that the Chinese dowel from the hardware store was porous and you could suck air through the dowel like it was a straw.
A two line system used properly works ok, but you often introduce air into the system when fueling, and that can cause hard starting sometimes.<hr />
Toni Clarke recommends the use of a coarse pitch screw screwed partially in the end of the vent line based on a similar principle, that sufficient air gets past the threads to allow the tank to vent, while not allowing any significant leakage of fuel, and also helps to lessen the smell of the gasoline.
Karol
Karol
