Menz 22x8 prop - Can't Balance
Just a quick question - I bought a Menz 22x8 prop, drilled it using the jig for a DA50. I'm using a Tru-Spin balancer.
I started with back plate, prop, balance ring and spinner and by the time I got done I had all of the set screws on one side and they are still at the top. The swing of the prop to center did slow down a little but not much. Took everything off and tried just the prop itself and it swung down and stopped dead pretty quick.
I took the other prop I bought out of the bag, put it on the balancer and it did almost the same thing.......... I don't know how much weight change it'll take to balance but I'm thinking more then I have ever seen before.
Has anyone else recently had any problems getting a Menz 22x8 prop balanced????
Just wondering if it's a possible batch of bad props just coming out, a difference in the wood from one end to the other etc.
I'm taking them all over to my brothers tonight to try them out on his balancer to just make sure they do the same thing on his.......................
My Feedback: (19)
RE: Menz 22x8 prop - Can't Balance
I quit using Menz props several years ago due their poor quality control and even poorer availability. As Jaka suggested, start carving and sanding one blade until it matches the other one. A dial caliper can assist you getting the blades the same thickness at the same blade stations along the prop blade's length. Also, always balance the prop by itself and not as a part of the prop / spinner unit. Once you get them all tuned up, they're still good props but you can buy Xoar laminated props for less $$ and they are pretty much ready to go right out of the bag.
ORIGINAL: GPutt33
Are you sure you're using the balance ring correctly? I've yet to find a need for one of those and have been able to balance all my props the old fashioned way. That leads me to suspect there is a reason for not balancing that is outside of the propeller's influence.
Hi Guys - Thanks for the info, let's see:
I'll use some putty or a little tape and lead to see how much weight I'm looking at removing.
I'll 2nd you on the Xoar, that's what I've been using and your right, with just a little bit of adjustment they are ready to go.
I do like to balance the prop, but then I go ahead and finish the balance by putting all the rotating parts together and then do a final balance. I mark all the parts so they all go back on the engine in the exact same alignment. You'd be surprised at how much the other components will take the perfectly balanced prop out of balance.
I bought the balance ring to just try it, and like I said I needed the extra weight on the nose anyhow. After a little trial and error I found that it does actually do a really good job. If your trying to be weight conscience however, stick to the tried and true methods of either sanding or using the clear finishes.
I did call up the shop I got it from and also DA, and neither one said they have had any calls with the same problem, so it must not be a 'batch' thing.
Thanks again guys
Thanks again guys
My Feedback: (12)
I had a Menz 24X8 that took a LOT of work to balance.. I really should have sent it back but I was in a bind for a prop.. I broke the glaze on the light blade and it took many coats of clear poly to bring it into balance.. Also flexing the prop by hand revealed a definite difference in rigidity between one blade and the other leading me to believe it was different density ..
Rick
Rick
Hi!
Remember to always sand on the front side of the prop so that the pitch isn't altered,
I never measure the thickness when I balance my props , just file and sanding untill the the prop balance!
Speed props also can be single bladed so a decent diameter can be employed.
On larger Menz props I found:
blade shape differences upper/lower blade
bore out of center both directions
blade angles out of whack
blade weight differences. (tip balance)
prop crosswise unbalance.
some props had all 5 issues.
up to 18" diameter the props were reasonably good, and the Menz is a good performer.
