SACHS 4.8 TWIN
My Feedback: (10)
SACHS 4.8 TWIN
Finally with a lot of help my Muffler Problem may be at an end My engine (older Twin) seems as it uses Sachs 4.8 2.4 Cylinders NOW I need a couple of standard mufflers Does any one out there have any under there bench!!! The mounting bolts are diagonal 30mm centres
Thank You All
Also thanks to those that have answered my previous thread....
Rob
Thank You All
Rob
RE: SACHS 4.8 TWIN
Rob, Try these guys. The Sachs 2.4 is the same as the Brison 2.4, I think. They will know along with a lot of guys that watch these threads. Dan,
http://www.bissonmufflers.com/en/index.html
My Feedback: (10)
RE: SACHS 4.8 TWIN
ORIGINAL: DAN REISS
Had a look But the mounting holes on my engine are across the Diagonal not in line
Thank You
Rob
My Feedback: (19)
RE: SACHS 4.8 TWIN
ORIGINAL: XTRA230
Hi Dan
Thank You
Rob
ORIGINAL: DAN REISS
Thank You
Rob
OOOps ... sorry, I just saw you were in Australia. You could still email them I guess. They will have the product.
My Feedback: (223)
RE: SACHS 4.8 TWIN
I have a pair of well-used but certainly operational stock Brison 4.8 mufflers. They have all mounting bolts and 10-32 smoke taps as well. You will need to use some liquid gasket, the gaskets are no longer avail. Can send a couple of pics if you like. They're yours for $50 shipped. Tony Schoenecker 678.687.3268
My Feedback: (223)
RE: SACHS 4.8 TWIN
