Walbro HDA-48D
1 Post
Walbro HDA-48D
I have a second hand Zenoah G45 that I picked up but need to replace the carburettor on.
HDA-48d are not easy to come by around here and cost both an arm and a leg (if you can find one)
Is there a suggested alternative or does anyone know a good source for the 48d?
DC
RE: Walbro HDA-48D
The HDA48 comes on the 62, try a WT76A from a 3.2 Sachs..Will work just fine..
The pulse port in the carb body will be in a different place, Dremel a channel to where it needs to be...
1 Post
RE: Walbro HDA-48D
Thanks guys,
Pat: the reason I'm after a repacement, the throttle shaft has been damaged by the previous owner by apparent attempts to fix a longer throttle arm to it.
I might be able to get it good though
The local Stihl shop carries the most common rebuild kits. I might see if they can get the right kit for me
Alternately, I might try to see if I can find a WT76A somewhere.
1 Post
RE: Walbro HDA-48D
Jim, you guys over there are lucky where because of the population, these shops tend to be bigger and have higher volume go through.
I live in a regional town with relatively small population but on the flipside, we enjoy the quieter life and less of what invariably comes with city life.
RE: Walbro HDA-48D
You guys down-under are WHAT?
Ari, you do have chainsaws to clear out all those funny trees don't you? Throttle shafts of many carbs are interchangable if the carb main bore is the same. Save them in your scrap box. They come in handy all the time.
My Feedback: (16)
RE: Walbro HDA-48D
Just a couple hrs ago two teen aged girls escaped from a juvenile detention facility down below my house and stole a car. They hit a 13,500 volt power pole between there and my house and laid it across the 4 lane highway. They escaped on foot. Deputy sheriffs have been roaming all around here this afternoon.
Which would you rather have? Peace and quite or population?
RE: Walbro HDA-48D
1 Post
RE: Walbro HDA-48D
ORIGINAL: w8ye
1 Post
RE: Walbro HDA-48D
ORIGINAL: pe reivers
Seriously, I'm going to pay a visit to the local Stihl place but Ralph has kindly offered to send me some parts
RE: Walbro HDA-48D
ORIGINAL: apalsson
http://shop.ebay.com/i.html?_nkw=HDA....c0.m270.l1313
