Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 R DA100 and DA100L IGN Modules Interchangeable? >
Old 08-30-2011 | 05:25 PM
ScaleRules's Avatar
Default R DA100 and DA100L IGN Modules Interchangeable?
Does anyone know if you can use a DA100 Ignition Module on a DA100L and visavi? Is timming compatable or should I just leave wellenough alone?
Old 08-30-2011 | 05:52 PM
Super08's Avatar
Default RE: R DA100 and DA100L IGN Modules Interchangeable?
As far as I know all the twin DA twin ignitions are the same. Just give DA a call to confirm. It's the quickest way to know for sure.
Old 08-30-2011 | 06:04 PM
All Day Dan's Avatar
Try DA. Dan.
Old 08-30-2011 | 07:16 PM
If it's a twin cylinder DA ignition you're good to go. They are interchangable.
