Back Pressure?
I just switched Pitts style pipes on my plane, previous pipe broke. And seems I have lost about 300-400 rpm's. The new pipe is a little larger. Is it a loss in back pressure causing the loss in rpm's. And if so would reducing the outlet's help bring it back.
IA
Did you retune the engine? I'm going to assume you are running a two-stroke, and they can be very responsive to muffler changes of any kind. I would be certain to retune properly before modifying the muffler.
With a general type "muffler" Pitts or can with down tube, it's usually more about tuning. There's a small difference in back pressure but not as much as one might thing. It's probably more about refelction, or when that back pressure bounces back into the cylinder. part of the intakeexhaust charge timing cycle. Where is becomes a lot more apparent is when you use pipes and the header length is wrong. You can end up with an engine that's hard to start or runs badly because of back pressure reflection,
For what you have focus more on re-tuning. You may still end up down a little bit, that's common with Pitts style mufflers. Pinching tips or reducing exit size won't get all that's lost back.
Due to many people not understanding the principles of tuned pipe operation, I have heard many people say that "two stroke engines NEED some back pressure". This misconception may have also come from the fact that exhaust back pressure can help a glow plug stay hot during idle operation for glow type engines.
AV8TOR
AV8TOR
Had to do some minor repairs due to a stall of the engine on Sunday. My falt, was in too big of a hurry to fly and did'nt retune again. Getting bad about that. Got it back out today. Ok. First thing is the old pitts was not made for this engine. It was much smaller than this one from RCGF. After initial start up gave it about 1/4 throttle for a couple of min's to warm up, then comensed to tuning. And now it run's even better with the right size pipe. I think the other smaller pitts was boggin it down.
