DLE 20 servo and mount
Old 12-06-2011 | 10:08 AM
Default DLE 20 servo and mount
What would be the proper throttle servo to use for a DLE 20? Also, when mounting in a Sr Telemaster, how is the best way to mount the engine-directly to the firewall, or do I need a special mount of some sort?
Old 12-06-2011 | 10:32 AM
Default RE: DLE 20 servo and mount
Mounting a DLE20 requires using a suitable sized beam type engine mount just like the one you would use to mount a glow engine, which is mounted directly to the firewall. Any standard size servo can be used for the throttle.
Karol
Old 12-06-2011 | 10:33 AM
w8ye's Avatar
My Feedback: (16)
I use a regular servo and this motor mount
http://www3.towerhobbies.com/cgi-bin...XATG7&P=ML
Old 12-06-2011 | 03:35 PM
ORIGINAL: w8ye
http://www3.towerhobbies.com/cgi-bin...&I=LXATG7&P=ML
What no arguments for using a metal geared servo with this gasser, or is it too small or too smooth to need a metal geared throttle servo?
Really just pushing some buttons here, I use regular servos for my small gassers also.
Happy Hobbydays to all, and to all a good flight.
Sincerely, Richard
Old 12-07-2011 | 07:17 AM
SpinnerRow's Avatar
I've been using Hitech HS-225MG for my throttle servos on my three DLE 20s.
Old 12-07-2011 | 09:07 AM
Hyperion DS16FCD for mine....
Thats a 5Kg mini servo with carbonite gears
Old 06-29-2014 | 08:18 AM
I don't understand the problem. Just because it's gas, you shouldn't need a bigger servo. Unless there is binding in your linkage, you just need enough torque to move the spring. I'm sure 3D flyers want a fast servo, but for a Telemaster any standard, or even mini will work on the throttle. I have a DLE 30 on a 1/4 scale SBack, and use a standard servo, not metal gears. It's worked for years.
Old 06-29-2014 | 11:50 AM
Roy, you understand you're addressing a post from 2011?
Old 06-29-2014 | 02:31 PM
Proper size beam mount will suffice.
Standard servo is good.
Personally, I always use the " KISS " method. Being Polish, this is not very hard for me to do. Hahahaaaa
" Keep It Simple Stupid "
Hangar 9 has a nice mount. I have one myself, but have yet to install it in any of my models. It is already drilled and should fit a DLE-20 perfectly.
Read the following:
Enter the Hangar 9 Ultra Engine Mount. The Ultra Engine Mount can be used with a wide variety of engine sizes; from .58 2-strokes all the way up to big 1.50 four-strokes. With this mounting system, there is no drilling and tapping necessary. Twin, slotted-aluminum beams hold the engine in place, but allow adjustment of the fore/aft position of the engine simply by loosening the mounting bolts.
Old 06-29-2014 | 03:59 PM
It's my guess that he was in hybernation and just woke up....
Old 06-29-2014 | 09:21 PM
True, but I didn't see it until 2014 and wanted to make a comment.
Besides there will always be people new to Gas and want to hear different opinions
Old 06-30-2014 | 01:20 PM
How the heck did this happen ? Did not notice it myself, until you brought it to attention.
Mannnnnnnnnnnnnnnnnnnnn, talk about loosing it, when you age !!! Hahahaaaaaaaaaaaaaaaa
