Dle 55cc Floating Mount
My Feedback: (14)
Check out this new DLE 55cc floating mount. I am going to try it out. Anyone know of any other floating mounts? I am still looking for a DLE 30cc floating mount.<a target="_blank" href="http://secraft.net/shop/step1.php?number=819">
secraft.net/shop/step1.php</a>
Dan
Dan
ORIGINAL: soarrich
Worn throttle servo gears.[X(]
ORIGINAL: Ram-bro
sowhat does a $200 motor mount buy you over your standard mounts?
ORIGINAL: 108buzz
Check out this new DLE 55cc floating mount. I am going to try it out. Anyone know of any other floating mounts? I am still looking for a DLE 30cc floating mount.<a target=''_blank'' href=''http://secraft.net/shop/step1.php?number=819''>
Dan
Dan
My DLE55 rubber isolation mount is 5 1/8" in diameter. Construction is standard aircraft plywood and balsa with a motorcycle inner tube used as rubber isolator. I also add carbon cloth to the plywood for extra stiffness. Weight is 4 ozs.
My design is based on the popular Hyde mounts because it's the best from an isolation point of view; it works the same except probably won't cost you 200$, either from Seacraft or Hyde
