wankel?
NY
Thanks guys, I understand the full size are a bit thirsty too, I was hoping for a gas engine for 1/5 scale. nothing on the internet other than the OS .30. anyone want to build me one
My Feedback: (16)
I had a flying buddy with one. It was powerful for it's size but quiet is not a term I'd use. It had quite a mechanical noise to it as well.
Also, remember that it ran quite hot. He flew the pants off it tho.
My Feedback: (27)
FL
The small os engine ran quite smoothly and was slightly quieter than a comparable .40. I ran mine without the muffler and was not noticably louder then my ASP .40 with muffler. Very low vibration. VERY thirsty......approx same power output as a .40 but drank like a .60. Also, VERY hot exhaust, similar to a 4 cycle glow engine. I used a smoke system on mine and just pumped the smoke oil into a short exhaust header.....worked just fine. I purchased that engine in the late '80s and retail at that time was under $225. They have gone up in price dramatically.
At the same time I owned a 1987 Mazda RX-7 turbo....also very smooth and high-reving but only got about 13mpg.
The large graupner engine was available only for a very short time...was rather expensive, and produced about 5hp.
PT
PT
Check http://www.ericksonmotors.com/
It's not a Wankel, but from your post mentioning 1/5 scale, you might be interested. Completely different engine, with a similar shaped package.
Good luck,
Dave Olson
Good luck,
Dave Olson
NY
I like the looks of that one too, but I want to make the move into gas, glow fuel is almost 20 bucks a gallon here in jolly ole england (and I do like things a bit out of the ordinary) if i'm going to pay 1500$ for an engine, it's gonna be gas so I can afford to run it
thanks for the suggestion though, maybe i'll build my own? (after I put my self through a couple engineering courses!)
