Headers
My Feedback: (29)
Has anyone tried this setup on a 50-55cc gasser? The airplane I am building is going to require a 45mm drop and this looks like the only way I can find to acheive that amount of drop. Not sure how good the canister is and I really wanted to go with an ES composites CF pipe so I may have to get this setup just for the header. Any other options?
ORIGINAL: SOLO_48
I wouldnt buy the on picture,it will brake by flange
I've got this on a DLE 55
http://www.gravesrc.com/RCGF_Caniste...anmuff55cc.htm
I dunno about more power, but it sounds better than a pitts and that flex pipe is pretty, well flexable
for mounting the thing.
My Feedback: (29)
That looks like it may work out well. I wonder if I can get just the header? Matt, I have seen the DA unit but I'm not sure it will have enough drop. I measured everything out and for the Lasers I am building I need a 45mm drop. The ES pipe is going to exit a little more then halfway down the Fuse.
