Final setup details on my new gas plane!
ORIGINAL: kmeyers
The differance is RPM. The load of an 18 x 8 is less at a given RPM so the engine will try to spin faster. The heat and friction go up with RPM. The Main Crankshaft bearings are sealed, if they get hot they will outgas their grease and fail prematurely. The CRRC 40 is not a Zenoah.
The bigger prop (20 x 8) will put more power into moving air at a lower RPM then into making frictional heat at a higher RPM.
The spinner is the same as any plane: Spinner backlplate, prop, washer, prop nut, spinner nut adaptor, spinnner and last spinner bolt.
ORIGINAL: gagallagher04401
20x8? alright I will get one. Is the plane flyable with the 18x8 that is on it though? What is going to be the difference?
Also is their a way to put a cone on this engine/plane? Would look a little nicer I think.
George
George
My Feedback: (20)
ORIGINAL: ahicks
The 20'' will act as an air brake as well. They don't ''coast'' like an 18''. Seen most easily on speeds on short final and any kind of down line when flying.
What size spinner typically for a plane of this size?
George
IL
Not sure if I understand this staement?
George
ORIGINAL: ahicks
George
What ever size spinner looks the best.
My Feedback: (20)
Thanks!
Another question, I have been balancing the prop (Wooden Top flite 18x8) How "perfect" does it need to be? I would call mine "close" not perfect. When It had nothing added toit it, it was WAY off, now it is "close"
Is that good enough? Just having trouble getting it "perfect" I would think perfect would not matter because as it gets chipped, dinged up etc... it will no longer be "perfect anyway.
George
George
I h ad a Quadra 40 with an 18x6 on a 72in. Stik Biplane. It wasn't enough prop. It would fly the plane, but an 18x10 worked better. I had ground clearance problems with the tail dragger, so a larger prop wouldn't work. I ended up with a 3-bladed prop. Measure from the prop shaft to the ground with the fuse level then figure the prop diameter you can use with adequate ground clearance.
#31
ORIGINAL: kmeyers
Well the pitch @ rpm = an air driven speed. If that speed is faster than the plane is currently traveling the plane accelerates. If slower it acts as a brake. When acting as a brake the effect is greater as the diameter increases.
George
ORIGINAL: ahicks
George
#32
My Feedback: (20)
Yeah people have mentioned giong with a bigger prop 20x6, 18x10. Plane has a 18x8 on it. I have no idea how to choose a prop for it. Engine is a CCRC 40cc engine.
IT will fly with my 18x8 right?
George
George
#33
My Feedback: (20)
VA
George
George
#34
My Feedback: (20)
Thanks!
Another question, I have been balancing the prop (Wooden Top flite 18x8) How "perfect" does it need to be? I would call mine "close" not perfect. When It had nothing added toit it, it was WAY off, now it is "close" Is that good enough? Just having trouble getting it "perfect" I would think perfect would not matter because as it gets chipped, dinged up etc... it will no longer be "perfect anyway.
George
George
#35
My Feedback: (20)
VA
Thanks!
Another question, I have been balancing the prop (Wooden Top flite 18x8) How ''perfect'' does it need to be? I would call mine ''close'' not perfect. When It had nothing added toit it, it was WAY off, now it is ''close'' Is that good enough? Just having trouble getting it ''perfect'' I would think perfect would not matter because as it gets chipped, dinged up etc... it will no longer be ''perfect anyway.
George
Thanks!
George
Do you have a good balancer?
#36
My Feedback: (20)
Thanks alot, so I am good then, I was worried I had to get it dead perfect.
The balancer I have is not the best but it works, they call it a finger tip balancer, but I use two tall glasses to balance it on, works pretty good.
Thanks again!
George
Thanks again!
George
