Where do I put the extra wire?...
Old 08-27-2003 | 11:13 AM
Default Where do I put the extra wire?...
Hello All,
I am in process of installing my RCS140 RE into my TF P51-B. I am putting the ignition electronics right behind the fire wall. I need about 2-3 inches of length in the wire for the spark plug, the ground lug to the engine case and the timing wire that feeds the ignition module with engine information. The timing wire going from the engine to the ignition module is about 10-12 inches long and the spark plug wire is at least 8-10 inches long. What do I do with the extra length (wrap, serpentine...) and where do I put it (along the mount, the fire wall...). What do you do with your extra wire? Thank you for your time and concern.
Old 08-27-2003 | 01:02 PM
Good heavens, you mean to tell me you've built a P51 and now the only problem is how to secure the excess wire? I know you can figure it out. Those plastic tie wraps make it real easy. Just keep it away from the exhaust.
Tom
