help with zenoah G38
hello all,
please help me.
i have a zenoah G38,
the plane has had 5 flights, the first 2 flights were not good, as they resulted in crash.
the first crash resulted in prop damage only.
2nd accident resulted in fuselage and wing damage, and the engine got a bent rotor, fuel nipple fracture, magneto tab (black wire) broken,
everything has been repaired and fixed.
however, engine does not run same as first time,
before, i could get 8000 rpm with an 18 x 8 prop, Zinger.
now engine gets 6500 rpm with same prop and with TWO, then all of a sudden, it will accelerate to 7600 rpm, with me not moving the throtel.
i can get engine to idle at 1500 rpm.
please see these videos i posted on Youtube, so you can see for your self.
thanks for any advice in advance:
http://www.youtube.com/watch?v=6Vu0kbOe4O0
at 17 seconds and again at 30 seconds, you will see it will accel to 7600 rpm, and then back down to 6400 rpm, with carb wide open at all times.
this is a video of it idling at 1500 rpm.
http://www.youtube.com/watch?v=859RkMpE5cA
has anyone seen this before???
what could be the matter??
i have open fuel filter and it is clean, no debris.
please help me.
RE: help with zenoah G38
Sometimes a bad throttle servo can make the engine sound like that. Maybe it got damaged in the crash. Also check the crankshaft run-out with a dial indicator. The G38 can get knocked out of alighnment easy. Antique can fix em good again. Capt,n
hi
i looked at that also,
in fact, this is the third tank.
it is a dubro 20 ounce tank
sullivan conversion kit
tygon 1/8 " tubing
welded on 1/8 " barbs for brass tubing
there is giant clunk in tank
the clunk and tubing in tank has a clip plus wire tie
there are only two holes into tank, one is vent
the other is fuel line
the fuel line from tank to carb has t shape connector , the part with T has short tube with a cap on it. i use this to refuel tank.
let me know your thoughts
tygon 1/8 " tubing
My Feedback: (16)
You've tried the needles.
You are not getting bubbles going into the carb
There may be a problem with the ignition? What about making sure the ignition coil is the thickness of a business card away from the flywheel?
What about the spark plug wire is it shorting against a fin?
Did you change spark plugs?
Is the ignition ground shut off wire shorting against the engine somewhere?
oh yes
i noticed that
if i am standing on that side of the plane, i can feel fresh gas land on my legs, it is cool (on the skin), not cool like it is a good thing.
i had engine going TWO, and noticed that with the choke valve open, the posterior half of the choke valve, is where the gas is coming out of the carb and out the side of plane.
is this normal??
i noticed that
is this normal??
i checked for this, did not see it.
just checked it, it is, in all 3 points, the center, right, and left side of coil, i can get that in there with minimal binding
What about the spark plug wire is it shorting against a fin? Just checked that, it is not touching anything.
Did you change spark plugs? i have not, but i did check gap, it is 0.025 inch (0.635 mm)
Is the ignition ground shut off wire shorting against the engine somewhere?Nope, checked that also. is the 7500 rpm not good or did you not like the sound of it when you saw todays you tube video?
thanks for all your advice, i appreciate you immensely in trying to help me, God knows i can use all the help.
hello everyone,
update
i have fixed it
please look at this:
http://www.youtube.com/watch?v=aWX7LSV_ZKE
what i did:
1. i put HSN and LSN to factory settings, turns out both were very rich.
2. i removed the choke valve leaf,
3. started engine easily, first flip.
4. ended up slightly richening the LSN (1/2 turn from factory setting, done at 1/4 turn at a time)
5. then HSN about 1 turn richer from factory recommendation.
6. tach read 7800 RPM with an 18 x 8 prop
7. it accelerates easily and without hiccup or stutter.
8 no midrange acceleration gurgling.
9. no more gas is coming out from posterior half of carb, and this is without a velocity stack.
thanks to you all for your advice.
i realized that the old G38 required a bell crank for the linkage to carb,,
but my engine came with a adaptor to rotate carb so that the throttle linkage would be straight shot from servo with a pushrod, however, this set up makes it so that the engine's carb has the choke leaf opening up against the flow of air, meaning the leaf sits perpendicular to flow of air, in such a fashion ,that relative to engine position, when choke is open, the anterior half of carb inlet will get more air, due to leaf , when it is open, will force air into anterior half of carb opening, then this forces air to go into mouth of carb and flow out the posterior half of the carb, taking with it gasoline that flows out the side of plane, instead of into the engine.
