DLE-50 Engine
Old 04-23-2012 | 03:15 AM
Rhino0_6's Avatar
My Feedback: (18)
Default DLE-50 Engine
Need some help! Looking for some parts for a DLE-50 engine need a piston, ring and cylinder head can anyone recommend a place to purchase these?
Old 04-23-2012 | 04:34 AM
w8ye's Avatar
My Feedback: (16)
Default RE: DLE-50 Engine
Do you mean DL-50?
I think you can just use the DLE-55 parts from Tower as long as you use the whole P&C set?
Old 04-23-2012 | 05:23 AM
Rhino0_6's Avatar
My Feedback: (18)
Yes I mean the DL-50. Do you think they would fit?
Old 04-23-2012 | 05:42 AM
w8ye's Avatar
My Feedback: (16)
I was told by someone that they did?
But lets wait around on here for a little bit and see who chimes in?
The usual problems with the DL-50 was the crankcase. The bearing pockets would wobble out of speck and the mounting ears would break off.
There was a on going change in the port design with the DLE-55. I don't know if this affected the crankcase or not?
Usually the piston/cylinder itself doesn't give much trouble on the DLE engines.
Is your piston galled with aluminum smeared across the ring and aluminum transferred to the cylinder wall on the exhaust side?
If this is so, you can remove the aluminum streaks from the cylinder with muriatic acid on a Q-tip and use a new piston/ring. But the problem still remains of getting a piston?
Old 04-23-2012 | 05:47 AM
w8ye's Avatar
My Feedback: (16)
Why not call Tom at Valley View R/C and ask him what old DL parts he might have on hand and if perhaps the DLE 55 P&C would work on it? Valley View R/C was a DL dealer long before DL changed to DLE. http://www.valleyviewrc.com/estore/
Tower will not have any true DL parts for Tower came along after DL changed over to the DLE 55.
Old 04-23-2012 | 07:06 AM
Rhino0_6's Avatar
My Feedback: (18)
Awesome thanks! I will do just that, It did mar up the cylinder wall just a tad but not to bad but would like to replace just to be safe.
Old 04-23-2012 | 10:17 AM
w8ye's Avatar
My Feedback: (16)
I bought a Sachs twin real cheap where someone had used Amsoil oil in it. Just needed pistons and rings.
Save your old cylinder. Someone may have exhaust thread problems and you can sell it to them?
Old 04-23-2012 | 04:18 PM
Rhino0_6's Avatar
My Feedback: (18)
Thanks for all the help talked with Tammy at Valley View they have everything I need! Thanks again.
