smaller canister muff than recomended
RE: smaller canister muff than recomended
Power will be a bit lower.
ORIGINAL: WhiteRook
if you went with a cannister muff thats rated for a 30 to 65cc on a 70cc would that be a problem ?
the diff in lenght is 3 inches and diameter about 9/16
Yes, the range probably is stretched a bit already.
@ Rich,
Side dump mufflers typically have no damping section. They just collect the exhaust gasses and spill them in free air. A small collector with large diameter stinger pipes will work just as well as a large collector with a small diameter stinger pipe, at the cost of extremely noisy operation.
@ Rich,
