DLE 30 cyl replacement
Old 05-14-2012 | 10:44 PM
Default DLE 30 cyl replacement
Hello,
I have broken a few cooling fins on my DLE 30 Head (landing gear broken off and...'[>:]',). Replacing it means replacing the cylinder. The engine is barely broken-in, is it safe not to replace the piston too?
Please state your experiences in this case, if any...otherwise I shall let you all know how this situation evolves.
Dino
Old 05-15-2012 | 12:52 AM
MetallicaJunkie's Avatar
Default RE: DLE 30 cyl replacement
if you have another 15 or bucks to spare, you can get a new piston and ring for about 15 dollars, if not then just get a new ring http://www3.towerhobbies.com/cgi-bin...e+30&search=Go
Old 05-15-2012 | 01:04 AM
av8tor1977's Avatar
Since you have to buy a ring anyway, better to buy a Frank Bowman ring. Much faster break in, better seal, more power.
AV8TOR
Old 05-15-2012 | 03:09 AM
w8ye's Avatar
My Feedback: (16)
A few broken fins, if that's all that's broken, never hurt anything. Just use it like it is
Old 05-15-2012 | 07:26 AM
+1 Run it til it seems to overheat then order parts. It might run for years. Also baffling can make up for the lost fins.
Old 05-15-2012 | 07:30 AM
Texastbird's Avatar
On a near new engine it would have hurt my pride more than the engine, I can see wanting to replace the cylinder on a pretty, new airplane. No need for a new piston, just the ring. There is good advise from Aviator if it isn't too hard to get one to Italy.
Old 05-15-2012 | 07:46 AM
I totally agree on this point. The fins are pretty soft and break easily. If the engine continues to run well, no need to do anything.
FB
Old 05-15-2012 | 08:22 AM
Use some JB weld...and stick em back on! May look good again...if done carefully!
Old 05-15-2012 | 08:46 AM
acerc's Avatar
I have heard a lot about those Bowman ring's. Would like to give them a try. Googled him and can't find a link. Anyone willing to offer up how I can get with him?
Old 05-15-2012 | 09:52 AM
Here you go for Frank Bowman: [email protected] or phone 505-327-0696
Karol
Old 05-15-2012 | 09:58 AM
acerc's Avatar
Thank You Sir!
Old 05-15-2012 | 11:45 AM
My Feedback: (34)
My DLE 55 is missing 2 top fins for the last 2 years
I fly it almost every weekend in a gaint scale p51 now<br type="_moz" />
Old 05-19-2012 | 04:11 AM
when replacing a cylinder be sure to do a thrust alignment.
Old 05-19-2012 | 05:15 AM
ORIGINAL: kerwin50
how do you do that?
