Spark plugs
Old 05-30-2012 | 04:01 AM
bigbird007's Avatar
Default Spark plugs
So, Whats the deal on spark plugs? I have a Midwest T-6 that I just put a G-38 in, an old one with a magnito. I decided it needed a new plug and went to the local saw shop and showed them the old one. He got out his conversion book and said "thats a resistor plug and here is the equivalent".
When I ran it, the ailerons twitched and the more throttle I gave it, the harder over they went. I put the old plug back in and the problem went away.
I guess all resistor plugs are not the same... Do they make aircraft plugs?
bigbird<br type="_moz" />
Old 05-30-2012 | 04:25 AM
BarracudaHockey's Avatar
Default RE: Spark plugs
He probably didn't sell you a resistor plug. Did it have an R in the part number?
Old 05-30-2012 | 06:37 AM
earlwb's Avatar
I would concur, I don't think you got a "Resistor" plug. He sold you a replacement plug as a substitute. Since he is a small engine repair shop, radio interference isn't something they deal with or worry about. I doubt the lawn tractors have AM/FM stereo or CD players in them yet.
Old 05-30-2012 | 07:19 AM
w8ye's Avatar
My Feedback: (16)
Most all chainsaws, weed whackers, and blowers made in the last 14 years come from the factory with resister plugs
The #1 spark plug in all these is the NGK BPMR7A
Old 05-30-2012 | 07:56 AM
Notice the "R" in the number!
Old 05-31-2012 | 06:39 AM
bigbird007's Avatar
I'll check but he did specifically mention that it was a resistor plug, btw it was a bosch plug.
bigbird
Old 05-31-2012 | 07:26 AM
earlwb's Avatar
Did you check the plug gap?  It might be set for too large of a gap.
A larger gap results in a higher voltage to bridge the gap and also higher voltages result in more radio interference RFI.
Old 05-31-2012 | 07:30 AM
Check to make sure the plug boot is on all the way. But has this engine been run on this plane without any interference problems before? Maybe something other than the plug?
Richard/Club Saito #635
Old 05-31-2012 | 07:37 AM
I suspect you got a bad plug. Take it back and get another one. Or why not just use the old one?
Old 05-31-2012 | 08:21 AM
bigbird007's Avatar
No, the motor installation is a new one, however when I put the old plug back in the problem went away.
The first thing I checked was the boot, it was on all the way.
I did not check the gap, I'll check that too.
Old 05-31-2012 | 06:03 PM
bigbird007's Avatar
The plug I got does NOT have an R in it so you are most likely right. I didn't get a resistor plug.
Thanks everyone.
bigbird
Old 05-31-2012 | 06:27 PM
w8ye's Avatar
My Feedback: (16)
One of my kids swapped out a plug on my Homelite 30 and put a non resister plug from their weed whacker in it.
It was hit city with the radio the next time I flew it until I changed the plug back to a "R" one.
Old 05-31-2012 | 06:58 PM
bigbird007's Avatar
The way mine ( a classic Midwest AT-6 ) was acting, it wouldn't have survived the take off. Sounds like you were lucky to get it back!
bigbird
Old 05-31-2012 | 07:07 PM
w8ye's Avatar
My Feedback: (16)
I just got "hits" in a certain spot in the air.
Old 06-02-2012 | 09:37 AM
The Vlach units later than 2002 needed the R-type plugs. The ignition relied on spark feedback to run and time properly. Non-resistor plugs would cause erratic running, apart from the radio interference.
Old 06-02-2012 | 12:47 PM
ORIGINAL: pe reivers
Just what do you mean by spark feed back?
Old 06-02-2012 | 03:36 PM
just that. The ignition reads the feed back from the HT wire and uses it. This is known as "forward coupling" in regulating cirquits.
Old 06-03-2012 | 05:27 AM
I would surely like to know how that works. There are no direct connection from the spark plug lead to the ignition circuit in the standard ignition circuit. Only thru the coil. There are no feedback connections.
Old 06-04-2012 | 02:55 AM
Mr Vlach knows how it works, I don't. I just know for sure that the ignition runs erratic when a non-resistor plug is used.
