Can this be fixed???
Old 06-12-2012 | 10:41 AM
Default RE: Can this be fixed???
You ever heard the saying, "you can lead a horse to water, but you cant make him drink"? If you would have sent the engine to Antique, you would be flying now.
Old 06-12-2012 | 11:10 AM
rcnats's Avatar
My Feedback: (56)
I didn't know he did this kind of work! Reading all the previous posts I did not see his name mentioned. If it was then my bad. Don't fret, if the local machine shop cannot remove it I'll get in touch with him. THANKS!
Old 06-13-2012 | 05:34 PM
8MILLSNIPER007's Avatar
The diamond cutters work very well to remove taps, I also use them to shape/ sharpen my lathe and mill cutting tools..
ORIGINAL: rangerfredbob
instead of stones I'd use diamond cutters, I've gotten several of the cheezy $7 12V harbor freight rotary tool kits that come with a whole bunch of the diamond bits and have found several uses for them, like drilling a hole half way through my windshield to stop a crack from continuing across the window... and when converting to a different wheel type on my 1/5 scale car I had to drill holes for pins in the hardened rear axle stubs, lubed up an 1/8" diamond bit and drilled on through. Most of them have abrasive at the tips so they can drill straight in, and a bonus is they don't wear out near as bad as a stone
