Crrc Pro GF50i Bearing Replacement
Hey guys,
I have to replace the front seal and bearings on my Crrc Pro gf50i engine. I've got new bearings and the seal. I've stripped it down as far as I can, but I'm stuck at getting the prop shaft and hub off the crankcase. I can't seem to get any further. How does one take the prop shaft and hub off?
Any help would be greatly appreciated.
Thanks.
Thanks.
RE: Crrc Pro GF50i Bearing Replacement
3 legged puller, put some tension on and then tap it. OR apply puller and heat the case with a heat gun if it doesn't go first time. Wear safety glasses!
The 26 I pulled last time had way too much red Loctite, so heat was needed.
If you don't have a small puller, tap two large flat screwdrivers between case and driver. Tap them in so they jam each side and then heat the driver/shaft with heat gun or carefully with a blowlamp.
