DLE55RA
Old 08-11-2012, 10:57 AM
mikes68charger
My Feedback: (34)
Default DLE55RA
Well Im supprised there is not posting just for this great new motor.
I don't like to get a motor untill others have tired them out first to see if there are any bugs.
Well I think this motor is great, as it will let me put a masive DLE55 in the same place as a DLE30 used to go as it do not weigh much more and dose not take up that much more space.
Ok, well I got me new DLE55RA yesterday from Troybuilt modles, as I have several DLE motors and Ifigured it was worth the risk.
So my first inpressions.
I love the angle back plug and rear muff, this is why I got it, Im putting it in a 74in ESM Corsair, with a Reg DLE55 it would not work well as the muffler out let coused issues.
I love the fact the carb has a nice metal barb fuel fitting
A bigger throttle arm to help out.
All bolts and locking washers are nice.
I put it on my test stand today, and once primed, it started with 4 flips, breaking it in with Xora 22X8 prop for the first gal on the stand.
I have no rpm data yet as Im giveing it at least 2 more cycles.
Mike
Old 08-11-2012, 11:39 AM
jeffk464
Default RE: DLE55RA
Yup, this RA layout is the way to go, it fits in with so many more models. I'm thinking about getting the 35RA, should be great for 70" warbirds and aerobatic models. It might even be possible that the 35RA will make it into pattern competitions.
Old 08-11-2012, 12:14 PM
SOLO_48
My Feedback: (8)
Default RE: DLE55RA
I wonder if the Head will fit regular 55
Old 08-11-2012, 01:07 PM
mikes68charger
My Feedback: (34)
Default RE: DLE55RA
I would say no. It has 2 intakes on both left and right side of the head
It sounds great thow!
Old 08-12-2012, 07:08 AM
VIRGINIA MODEL BUILDERS
My Feedback: (159)
Default RE: DLE55RA
NO is the answer because of the ports.
Old 09-08-2012, 01:29 PM
chicks5
Default RE: DLE55RA
I am rebuilding the motor mount plywood on a G.P. P atty Wagstaff. It had a Fugi motor on it and I plan on a DLE-55 replacement.
There are a lot of holes in this firewall plywood. How thick would you recamend to mount a DLE-55? Thanks
Old 09-08-2012, 04:16 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Default RE: DLE55RA
ORIGINAL: chicks5
!/4" to 3/8 quality aircraft ply is all that is needed. Don"t worry too much if you need to open it up for the carb either. Any material in the center inside the stand offs is not contributing any to strength.
Old 09-11-2012, 11:13 PM
Chris Nicastro
Chris Nicastro's Avatar
Default RE: DLE55RA
Can anyone compare the two 55's in terms of motor mount stand off distance? There is no info on Tower or DLE from what I see to tell me if there is any difference in the mounting stand off lengths. My guess is there is no change but Id like to confirm.
Looks like a promising engine and Im thinking of getting one. I can tell you the OS 55GT is HUGE in comparison so if hiding the engine in the cowl is your concern the OS is hard to work with on typical scale models.
Thanks!
Old 09-12-2012, 11:03 AM
Chris Nicastro
Default RE: DLE55RA
So I determined there must be no difference and ordered the engine last night, lets see how this goes! I used an ad code on Tower to get $50 off and so I ordered the digital tach, total was only $405 with 2 day shipping.... Not bad!
Old 09-30-2012, 04:14 AM
ozzieflyer
Default RE: DLE55RA
So have you got the 55RA yet?
If so, have you run it?
I want to put one into one of these
http://phoenixmodel.com/Default.aspx...atId=63&id=313
Old 12-07-2012, 03:59 PM
Michel
Default RE: DLE55RA
Hi
I just received my new DLE-55RA , and , I am quite impressed . At first look ,.... very clean and well packed . The first thing I noticed was that there was no tube , comeing from the crank-case to the carb ,................... finally . I think this is one of the items , that makes it look clean . The engines supports look very beefy . This is an engines built expressly for RC through and through . I really like the slanted plug look , lowers the profile . And of course , lets not forget about the ignition system , finally ,.................. we can use a 2 cell lipo ,............... what took them so long ? .
I now have a , dle-55RA , a DLE-35RA X2 , and a DLE-20 .
Michel
Old 12-10-2012, 06:10 AM
roknHS
Default RE: DLE55RA
I'm considering this motor but, I need to know the length from the back of the carb to the back of the prop for cowl spacing.............can't find a 3 view drawing with measurements. Anyone got a motor and tape handy?
I'm assuming the rear muffler does not extend past the back of the carb............am I right?
Old 12-10-2012, 11:10 AM
TimBle
Default RE: DLE55RA
correct
Old 12-10-2012, 01:39 PM
roknHS
Default RE: DLE55RA
Thanks for verifying that muffler question...........How about the overall length??
Old 12-13-2012, 12:07 PM
Tone Price
Tone Price's Avatar
Default RE: DLE55RA
ORIGINAL: roknHS
Please check my attachments. It's looking like 171mm to the standoffs.
ID:	1829605   Click image for larger version
Old 12-13-2012, 02:07 PM
Flyer88
Default RE: DLE55RA
My friend just swapped out a DA50 with a DLE55ra and discovered it was about 1/4" to 3/8" longer due to he rear muffler.
To get a nice space at the spinner he might have to cut back the engine box.
Old 12-21-2012, 01:02 PM
Waldo20
Default RE: DLE55RA
Hmmmmmmmmmm, so the firewall mounting patterns are not the same as the side exhaust 55.
Old 12-21-2012, 01:10 PM
Tone Price
Tone Price's Avatar
Default RE: DLE55RA
ORIGINAL: Waldo20
Correct, different. Please check my attachments for a good side by side of both.
ID:	1832595   Click image for larger version
ID:	1832596   Click image for larger version
ID:	1832597   Click image for larger version
Old 07-13-2014, 04:46 AM
chandley43231
chandley43231's Avatar
love this motor but fuel is coming out of carburetor an will no start now what should i do ?
Old 07-13-2014, 05:45 PM
captinjohn
Pinch off the fuel line to carb with a hemostat and continue to start it. When & if it starts remove the stat & see if it keeps on running. Let us know as you go. Good luck .
Old 11-06-2014, 04:49 AM
chandley43231
Lol turns out the ignition was seperated in the coil connecting to the spark plung mid get a spark but it was intermittent motor runs fine it must of happened in. Crash before I got it hopefully all better now
