Plug wrench
Old 11-10-2012 | 12:13 PM
BubbasanJohn's Avatar
Default Plug wrench
Hey y'all,
What size and where did you get your plug wrench for your gassers? Thought I had One kicking around the shop but Csnt if d it. Thanks
Old 11-10-2012 | 12:34 PM
My Feedback: (19)
Default RE: Plug wrench
ORIGINAL: BubbasanJohn
Hey y'all,
It depends on what plug you have. The very common NGK CM-6 plug has a 14mm hex and I prefer to use a deep socket on a 3/8" drive ratchet. Other common sizes are 5/8" and 3/4". If you want a low cost, dedicated wrench, just about any good saw shop should have one to fit your plug. These usually fit (2) different sized plugs and have a short handle welded in place.
Old 11-10-2012 | 12:44 PM
MetallicaJunkie's Avatar
i just use a deep socket 14mm.... all my gassers use cm6 plugs so im good to go
Old 11-10-2012 | 03:29 PM
My Feedback: (19)
ORIGINAL: MetallicaJunkie
Yup! When trying to use the cheap wrenches supplied with some engines and lawn equipment, I can never quite tell when the plug is tight. A normal deep socket and 3/8" drive ratchet gives a good solid feel.
Old 11-10-2012 | 08:18 PM
Thanks for the info guys. I assume most auto parts stores should have the 14mm socket?
Old 11-10-2012 | 08:37 PM
w8ye's Avatar
My Feedback: (16)
True
