unknown motor
Old 09-12-2003 | 02:42 AM
Silly me's Avatar
Default unknown motor
I have bought a extra with a motor on the nose that I would like to know what make is is..
I'll post a pic this afternoon.. But the motor has a big sign with www in a sirkel, and its a twin 70cc ( I think ) the electric ignition is a 3w (big sign) the mount is 3w the prop is a 3w. but looking on the 3w site www.3w-modellmotoren.de there is no 70cc twin, but the motor look very close to the 3w-85b2 but not that close, the ports on the cylinder is exiting on a 90deg angle not +-110deg also the backplate is more square , than round.
By no means do I need to change or set anything on the motor as it is spinning a 24x10 prop well.. I would just like to know as I thought a have a 70cc twin 3w motor.
Old 09-12-2003 | 09:39 AM
Antique's Avatar
Default RE: unknown motor
Early model 3W no longer made....If it has 4 separate little right angle mounting lugs it's a very early model..Be careful, they break off easily in a crash..The later models did away with the lugs and are cast in a rectangle...Same engine otherwise...
