New Evolution 10cc gas engine
#852
OH
RE: New Evolution 10cc gas engine
Cool I need 2 for my hanger9 b-25 of corse if they have it ill call Tuesday thanks so much remember Monday is a federal Holliday so for sure on wensday I sent al pics of my neccells with the 10 cc on it.
#854
CA
Where can I get and where is the source for the fuel filter supplied with this engine?
FWIW, my flying experience shows this engine is equal to or more powerful than the OS46AX.
Jerry
Jerry
#855
IL
Hi Jerry,
We have the two filters now in our warehouse and should be available to ship shortly. EVOA105 (inline) and EVOA106 (felt clunk).
Jimmy
Jimmy
ORIGINAL: jerdavis
Jerry
Jerry
#856
SC
I Can't really say how much power it has,cause all ive done is bench runs..i hope its stronger than the os 46ax..i have a stinger ii with os 46fx..my guess its 5.5 to 6 lbs and it pulls it good..i'm putting the evo 10 on hanger 9 katana and it weighs 3.5 empty hope to get it in at 6.5...maybe ...hope i'm not dissappointed with the engine..
#857
I have found the supplied fuel tubing doesnt flex enough . I was going to use a 6oz tank but the clunk wouldnt get anywhere near touching the bottom . Its slightly better with a 8oz tank but if I go upside down with anything under 1/2 a tank of fuel its going to suck air . Is there a heavy felt clunk or another way around this prob. I know of the tanks with the swinging brass clunk and lines that dont use any tubing on the inside but there pretty pricey here in Aus. plus theres no felt clunk on the end .There called roto flow tanks and the smallest size is 10 oz which is a bit big for my plane . Any ideas ? Cheers the pope
#858
SC
wonder if you modify an original clunck by cutting the nipple off of it and drilling it out so that it would slide over your hose and use it for a weight and then put your fliter on the end...just a thought
#859
OH
Ok here a good question can I run just one 6.6 life battery why harness it to each switch on off that is instead of having 2 batts independent one for servos an one for egnition
#861
SC
i'm a glow guy myself...but you can do research on the ibec...i'm gonna try two 1300mah life batteries which will be like one nimh far as weight......they make a 700 mah life i think..i'm not for sure how much the ignition will pull...
#862
You'll be fine running the 2 switches from one battery. The guys running the bigger gassers (20-30cc) do that frequently. That setup run from a single LiFe becoming more and more common place? I've been running that way (without an IBEC, Rcexl opti switch only) for the last 3 seasons....
#863
IL
The ignition draws anywhere from 250-450 mAh depending on the usage, but it averages around 200-300. I would suggest using a minimum of 600 mAh pack. The question of using one battery for both ignition and Rx has been addressed previously in this thread, but as a general rule Horizon does not support this method. There are a lot of guys using an ibec to isolate the Rx from the ignition so they can use one battery but it is at your own discretion, and we recommend 2 batteries.
Pope,
I would suggest you use the supplied fuel line and filter in an 8 oz tank. We have a lot of time using that exact setup and there have been no issues with fuel draw/pickup after MANY hours of flying. The supplied setup will drain the entire tank without a problem. Don't take my word for it though, maybe others can verify in their setups as there's been many people reporting flying.
Hope this helps guys.
Jimmy
#866
ORIGINAL: jspauld2
Pope,
Jimmy
#867
When emptying a gas fuel tank with felt filter/klunk one can note a fairly long period where the fuel pump draws a mixture of air and fuel. It is my opinion that the small consumption of gas thus tolerates a felt klunk that does not stay immersed, but rather wicks fuel to the felt where it is gets drawn to supply the engine. While running, the added vibration is constantly splashing the felt klunk and keeping it wet with fuel.
I've never experienced a fuel supply problem with a gas engine when using a felt klunk.
#868
O.K. I'll suck it and see . It just seems to go against everything compared to glow which I know it isnt . Even if I have to do any upside down flying early on in the flight and then stay level I can live wit dat . Maybe as the clunk gets wet it weighs more so ithat may help the cause . Thanks for all your replies . Cheers the pope
#869
SC
i done some more heat cycling on the engine tonight...running it at different rpms and keeping a check on temp...from what i can tell compared to my os 46 fx,its definitly stronger than it ,but i don't know if the 12" blade is gonna be the preferred blade for me...the 11" seems really good..i tried the 12" and it really cuts its back...maybe after some more break in it'll do a lot better...gone through about a half of gallon on gas..me personally i like two strokes to have good rpms and don't worry about what blade size long as it works well...2 strokes are for sport flying and the four strokes are 3d....just my opinion.....
#870
My Feedback: (14)
Here is one possiblity for using one battery for ignition and the servo's. I use a 6.6 LIFE with it. You can regulate the voltage to 6v for the ignition.
https://www.troybuiltmodels.com/items/WRCIBEFV2.1.html
Dan
Dan
#871
Geez, I suppose if you were concerned about filtering any potential RF issues? There's really no need to be concerned about regulating the voltage when running a module rated at 8.4v. If your receiver can handle your battery, your ign. module can as well?
I'm all for the opti switch plan, but you can do that using an RCEXL switch (made by the same RCEXL that makes many/most of the ign. modules we're using), with a street price of 20.00 or less?
Regarding filtering, worry if you like, but there are an awfull lot of us on 2.4 that have been running that RCEXL switch on the bigger engines, without issue, for years now?
Just pointing out that 50.00 may be purchasing insurance that's really not necessary. If it makes you sleep better, sure, go for it!
#872
IL
Pope,
You are correct in that Tygon does get harder over time and actually get so stiff you need to replace it. Viton actually doesn't get harder when soaking in fuel, so it will get softer and more flexible as the weight of the clunk and flying causes it to flex more.
Jimmy
Jimmy
