New Evolution 10cc gas engine
#1677
I think I'm in agreement with Franco...
The 20cc engines while they may weigh the same as some of the 15cc engines, are a much larger form factor and swing larger props, they can be more difficult to fit in the nose of some of the true .60 size planes, and you can end up with prop clearance issues since your swinging a larger prop than was originally designed for the plane…. You can't fit a dle-20 in an ultrasport .60 for example without chopping off the nose, and a 14" prop is about the max you'll fit without mowing the lawn. The 15GX fits in there nicely with 0 modification though. And quite honestly, for a .60 sized sport plane, you don't need any more power than a 15cc offers… Whats more than unlimited vertical? unlimited vertical plus 1 :-) In many cases opting for the 20cc may work better, but there are cases where the bigger prop and the bigger form factor cause more problems then they are worth. It really depends on the plane.
For a cub, my thought is mainly "less is more"
#1680
If you are considering the 10 or 15 evolution budget for a new muffler. It is a POS. and yes i have tried all of the recommended fixes to keep it from turning and coming loose. The 15 seems to perform about like a good 61 glow motor. Its running about 11.5k with with a 13x6.
If the long bolt is over-tightened, it will break when the muffler gets hot and you will loose the rear end of the muffler.
#1681
I can second the steps Joystik outlined for the muffler. I also found that the 15cc muffler seems to have better seals in the supplied muffler. My only remaining question has to do with the RPM (tachometer) lead that comes from the ignition box. In the lead there is a small plastic device halfway down the lead. What is this device? Anybody know?
KKKKFL
KKKKFL
#1682
My Feedback: (278)
NC
I've owned over 4 evolution engines and i will tell you.....they all are terrible and dont produce the power of a OS engine or saito.I had one Evolution 120 2 stroke glow and it was weak and had problems out the box.They are made cheaply with less than standard materials..just my opinion!
#1683
The secret to keeping the muffler from coming loose is to get the long bolt snug, but not super tight, then tighten the locknut. In addition to that, I removed the "O" rings and used Grey Permatex to seal all the joints, including the bolt threads. Let it harden for at least 24 hours. Grey is good for up to 400 degrees. The Permatex will also stop the leaks between the joints. You can also use it between the engine and muffler. I use a fine wet-stone to polish the muffler and engine mating surfaces, then use the Permatex instead of the gasket that comes with the engine. Make sure you clean all the fine metal particles from the engine so they don't get into the cylinder.
#1684
Use Red loktite thread lock and follow joystik's procedures. As for power the EVO line is excellent
the poster saying they are cheaply made is comparing nitro
engines NOT gas. There's a huge difference. These gas engines blow away nitro
power. My only concern is longevity. I've been RC'ing since 1963.
#1685
The CDI ignition is only 3.4 oz. and looks to be quite a bit smaller than the Rcexcel units for CM-6 plugs.
The info regarding the bushed conrod is incorrect. On another forum, two reps from HH jumped in and explained that it was a production change, and that the engine will have German needle bearings on the conrod, they're also testing with less oil in the gas as well The carby is not pumped, just regulated. The manual shows muffler pressure being used to the tank vent line.
I look forward to seeing some reviews of this engine.
Pete
Just realized I had an RCexcel for CM-6 on the bench, 3.6oz. not much of a savings[&o]
Pete
#1686
My Feedback: (19)
I have a question to you guys with 10GX.
I local club member is trying to go gas.
Do you think the engine will be able to pull around the Great Planes J3 Cub 60size?
http://www3.towerhobbies.com/cgi-bin...?&I=LXJ569&P=7
I was told the weight would be around 8 pounds. Not sure how he build the plane, but spec says 9.5 ~ 12 pounds.
He doesn't need the plane to do loop or roll, just want something flying slow.
What do you think?
What do you think?
#1687
Has anyone ever tried running one of these engines in reverse? I flew two of them this summer in preparation for them powering a Seagull Piper twin Comanche. Counter-rotating props would solve a few problems for me, if it can be safely accomplished. Thanks in advance for sage advice!
Just found earlier posts concerning reverse running. I am interested if the mods become available. I also have two 15's that are going into a VQ P-61, and counter rotation would be nice.
Don
Don
#1689
Don
Don
Right, I had inquired about this some time ago. Short answer is "as is", the 10GX won't run in reverse properly, however if there was enough interest then they would consider marketing a reverse rotation 10GX. I'd love to have one as well… unfortunately I doubt the interest is strong enough for this to happen.
#1691
Can someone please give me advice. I have bought a 40size H9 stick and a 10cc gas Evolution engine. The space is quite tight and also looks like it will end up nose heavy. I am thinking about moving the ignition back to help the CG. My question is how close can I get the ignition to the Rx without RF noice being a problem and also the ignition and rx batteries? I'm using aJR 8ch DMSS rx.
My next question is this H9 kit comes with steel pushrods for the throttle and steerable nose gear. They have nylon clevises at the ends but run quite close to the ignition unit. Would they act as an aerial for RF noice going back to the radio gear?
Thanks for any help
TtT
Thanks for any help
TtT
#1692
ON, CANADA
I have the GP Big Stik 40, I think they are somewhat similar the H9 Stik 40. Mine was nose heavy, so I put the Rx (4 cell nimh) about half way back towards the tail and she balances perfectly. I put the ignition on the throttle side and used a golden rod for the throttle. I left the steering linkage metal and put the ignition battery on that side. I have my receiver in front of the servos. I use Frsky rx and have not had one glitch in about 3 1/2 gallons of flying. Here is a pic, excuse the mess I had a fuel leak at the end of the season. There is a bit of extra wiring in there for telemetry.
#1693
I converted my H9 stick to a taildragger and mounted the servos in the tail. I also have the 5 cell NiMi battery mounted just behind the wing. No problems with the balance that way.
#1695
Will this supplied Viton fuel tubing become softer once saturated with fuel for awhile? I have an 8oz tank but the clunk doesnt fall to the bottom as I turn the tank as the tubing is too rigid.
I also dont really want to use this felt clunk if I can get away with it. Surely the in line filter will catch any debris. I dont like the felt clunk as when you fill up it will catch the dirt on the wrong side of it unless if you have a separate filler but then it will flood the carb unless you can nip the carb line each time. Plus I feel you will have to leave fuel in a tank with a felt clunk as it will get that fuel/oil glazing on it. Any tips with this?
Thanks TtT
Thanks TtT
#1696
Thanks TtT
Thanks TtT
Even if you filter the fuel when you fill up your tank, there can be quite a bit of debris that can enter the fuel tank from the muffler pressure line. A regular filter on that line will help some, but it will not block the very small particles.
#1697
Thanks TtT
Thanks TtT
#1698
Thanks TtT
Thanks TtT
Might be worth getting it running with the recommended setup first, and then switch it over to what you want to do afterwards. That way if there are issues its easier to diagnose later.
#1699
Thanks guys I appreciate your help, this really helps me
Brian are you saying you use no felt filtering and just the in line filter?
That's the problem I had and changed to Tygon for inside the tank. I was having a lot of deadsticks and thought there was a leak. I pulled the tank and noticed the clunk not flexing properly on the Viton tubing. I changed the tubing and I changed the clunk to a heavier brass sintered clunk and no more deadsticks and no air bubbles in the line.
#1700
Felt Clunk
Will this supplied Viton fuel tubing become softer once saturated with fuel for awhile? I have an 8oz tank but the clunk doesnt fall to the bottom as I turn the tank as the tubing is too rigid. I also dont really want to use this felt clunk if I can get away with it. Surely the in line filter will catch any debris. I dont like the felt clunk as when you fill up it will catch the dirt on the wrong side of it unless if you have a separate filler but then it will flood the carb unless you can nip the carb line each time. Plus I feel you will have to leave fuel in a tank with a felt clunk as it will get that fuel/oil glazing on it. Any tips with this?Thanks TtT
