The write prop
Old 09-13-2003 | 09:49 PM
X-Cellant's Avatar
Default The write prop
I have a Ohio R/C Ultimate cuppled to a Zen G-62. It waighes in @ 18.5#. I have tried a 22/10 and a 22/8 Zinger and I am not too happy. Before spending the bucks on a composit props. I would like to hear some feed back from others with this kind of set up.
Old 09-14-2003 | 10:48 AM
My Feedback: (31)
Default RE: The write prop
What is the problem? The 22/8 is a common prop for this engine. Zinger are kind of a sport prop IMO. If you looking for more pull a Menz S, Bambula, AirWild, 3W and many others are well known for loading the engine a little harder and providing more OOMMph.
Increasing pitch loads the motor harder and may provide additional speed and better down line braking. Stay with the 22" prop for best results, a 23/24" would be even better if the Zenoah could pull it. It depends on what your looking for. Prop diameter only effects the static thrust delivered and is a variable of RPM... Pitch is a speed thing for the most part...
Composite props are heavy, much heavier. They typically have a narrower chord and are easier to turn. If you want to go hear try a Mejzlik 22/8.
