DLE carb problem
Old 01-01-2013 | 01:07 AM
Default DLE carb problem
hello,
i have a problem in my 55cc DLE engine, as it dies ones it reach to the idle speed
also the transition from high to low RPM takes about 4 or 5 sec to reach the idle RPM
so i doubt about the carb, so i will try changing it as i lost all my chances to tune it
does one tried this one before from hobbyking ??</p>
http://www.hobbyking.com/hobbyking/s...idproduct=7721</p>
Old 01-01-2013 | 03:45 AM
Lifer's Avatar
Default RE: DLE carb problem
Have you tried to adjust the low-speed needle? Sounds like a lean condition to me.
Old 01-01-2013 | 08:31 AM
w8ye's Avatar
My Feedback: (16)
YES,
The low speed needle is too lean
Old 01-01-2013 | 08:53 AM
i made all the magic with it
but it still not working properly
Old 01-02-2013 | 09:35 AM
Richen the low end by turnign the low needle (screw closest to the engine block)out by a 1/8 of a turn.
