Bosch Sparkplug Identification
Old 01-04-2013 | 08:06 PM
All Day Dan's Avatar
Default Bosch Sparkplug Identification
I have some Bosch sparkplugs that have WSR6F stamped on them. There is other printing on the insulator that starts with R10 and then three digits. They are all different. Does the printing on the insulator mean anything and are they usable in my 50cc engines? Dan.
Old 01-05-2013 | 05:33 AM
BarracudaHockey's Avatar
Default RE: Bosch Sparkplug Identification
The R means its a resistor plug which, given your (I won't say obsessive ) concern for radio interference is a good thing.
its a chain saw plug
Here's the cross reference to other plugs and I don't see the CM6 listed but hey, throw it in there and see if it runs, your motor won't explode.
http://www.sparkplug-crossreference....BOSCH_PN/WSR6F
Old 01-05-2013 | 05:37 AM
Make sure to check it's reach length to ensure that it will not contact the piston.
Karol
Old 01-05-2013 | 08:17 AM
Thanks you two. It's just what I was looking for. Dan.
Old 01-05-2013 | 10:50 AM
The 6 range may be too cold. More likely use a 7 range plug
see bosch catalog http://www.bosch.com.au/content/lang...tralia_Web.pdf
page A14 a15 for type code markings
Old 01-05-2013 | 04:23 PM
Bass1's Avatar
Been using those plugs on several Brison 3.2 engines for many years now and they work great.
Old 01-06-2013 | 08:26 AM
Thanks pe for all that information. Thanks Bass. I'll be using them in Brison 3.2's. Dan.
Old 01-06-2013 | 10:04 AM
Bass, I'll be gapping the plugs at .020 and I'm using a CH ignition. Is that what you're doing? Dan.
Old 01-06-2013 | 10:33 AM
Bass1's Avatar
Dan, Yes exactly. I do have the R10 stamped on the insulator but I don't have the 3 digits on the insulator however I do see 3 tiny digits engraved on the base next to the engraved WSR6F- Brasil . My plugs are quite a few years old though (ancient).
Old 01-06-2013 | 11:41 AM
Thanks again. Dan.
