Frank Bowman ring
Old 02-25-2013 | 09:19 AM
Default Frank Bowman ring
I bought a MLD 70cc twin for my third scale Fokker triplane. This engine simply would not hand start for me. I used a friends starter to get it going. Even after a few runs very little compression. Took the jugs off and everything looked ok to me. As I had bought this engine directly from China any real support probably would not be happening.
Anyway, while considering calling Troy Built and ordering a DLE 60CC twin to replace the MLD, I remembered something about some guy making rings for rc engines. Alittle resource and I found the name Frank Bowman. E-mailed him what I wanted and a few day later I had two new rings in my mailbox.
Installation was easy. Reinstalled the prop and gave it a flip and now had good compression. Not bad as it hasn't had any breakin time. Fueled up the engine and choked it with the ignition off with throttle all the way up and flipped it until I saw fuel coming out the exhaust. Choke off, throttle at high idle and ignition on. First filp and the engine was running. More starts were just as easy.
Thanks Frank!!!
Dave N
Old 02-25-2013 | 10:10 AM
av8tor1977's Avatar
Default RE: Frank Bowman ring
Yep! You can't beat Frank's rings. I use them in all my engines. Someday soon I am going to tear down my twin cylinder air compressor, and when I do I am going to put Frank Bowman rings in it too!!
AV8TOR
Old 02-25-2013 | 11:19 AM
BarracudaHockey's Avatar
Ditch the stock ignition and it will probably run even better.
Old 02-25-2013 | 02:59 PM
Have Frank's rings in ALL my engines, and a big +1 for ditching the stock ignition and going with an RC exl unit.
