Question on propping a Brison 3.2
I've got a Brison 3.2 and I'm using Bambula props. With the 20 X 10 prop, I get around 7100 rpm. I wanted to try a lower pitch so it would be more stable in hover. I tried a 22 X 8 and I'm getting only 6600 rpm. I haven't had more than two flights with it yet, but it seems to be fine. Should I run this prop on this engine? Is 6600 within the range this engine runs well?
I realize that because of the way Bambula props are designed, they usually get less rpms than other props of same size. Here's the quote from their site:
*Do not expect these props to be "RPM Kings". Bambula Power props do what props are supposed to: MOVE AIR! (or through it; depends on your point of view) because of this your engine will experience a heavier load and will not turn as many RPMs as it did with other props. Bambula Power Props provide maximum PULL POWER.
My Feedback: (48)
NY
On the brison and fpe engines around here we tend to see 7200 to 7500 with a 22x8 to 22x10 bolly prop.
I havent run a bambula prop but I would think you shoud see at least 6800 to 7000 rpm on a broke in 3.2.
What oil mixture are you running? How much fuel do you have through the engine? All of these things matter alot more on a gas engine than on a glow motor. The Brison will make alot more power after a couple gallons of gas.
Good luck with it and enjoy it as it is a great engine
Fred
Fred
Derf, I've got about 6 gallons thru it and I'm running 100:1 Amsoil at 80:1 (as recommended by Amsoil for racing or harsh environment).
Thanks.
I
Thanks.
I
