quadra 75 ?
Old 05-12-2013 | 10:05 AM
My Feedback: (38)
Default quadra 75 ?
ive got an older quadra 75 , and the carb wont take any fuel in , the engine has plenty of compression
, any ideas?
Old 05-12-2013 | 10:53 AM
tkg
Default RE: quadra 75 ?
Rebuild the carb, check for improper mounted gaskets or leaks in the crankcase
Old 05-12-2013 | 11:04 AM
My Feedback: (38)
the carb is new , mabey something is stuck inside it
Old 05-12-2013 | 11:23 AM
Make sure the passage between the crankcase and the carb is open. If the mounting block or a gasket got placed improperly, it could be plugged.
(show ads)
Forum Last Post Threads Posts Moderator
WattFlyer Site News, Announcements, Upgrades
Old 05-12-2013 | 11:29 AM
My Feedback: (19)
ORIGINAL: Rodney
(show ads)
Agree ..... these old Quadras had a gasket between the carb and the reed housing that seemed prone to closing up the pulse hole, perhaps from shrinkage? I have seen the hole completely closed off. This might be an area you might want to look at. I usually just make a new gasket with more material in the area of the pulse port.
Old 05-12-2013 | 12:08 PM
My Feedback: (38)
thanks , i'll check the ports . someone tried to plug up the compression realease feature on this engine
and it didnt work, so i have a leak there. dont know how in the he!!! im going to fix this. its got an allen bolt screwed
into it in an atempt to seal it , but it leaks. JEEZZ
OKAY now i have two problems , first , the engine has the wrong carb and base gasket , so the correct ports are blocked.
its supposed to have an SDC-80 , IT Now has a wt159
if i can find a used SDC-80 THAT would help
