I have a Q-35 and would like to find a prop shaft adapter that is shorter than the stock one. Also, how do you go about removing the old one? Is it just threaded on?
They screw off/on. If you know someone with a metal shop they could make you one or possibly cut-down the stock one. if not you could try B&B Specialties or contact Ralph Cunningham as he used to convert them
