Flex exaust pipe for DLE 20
In what way do you mean modify?
I assume the 30 has a bigger hole and the bolt holes are larger, further apart ?
Are you saying I can just woller the holes on the 30 bolt holes and use some JB weld for a gasket?
Brian
Brian
The beam mounted RCGF 20 is pretty similar to the DLE 20, but not real sure how the muffler mounting bolt centers compare. Assuming they're pretty close. BP Hobbies is showing this header, but it's out of stock.
http://www.bphobbies.com/view.asp?id...9&pid=E2674925
They also show this one, which appears to be in stock?
http://www.bphobbies.com/view.asp?id...0&pid=E2674933
Might be worth a phone call?
