DLE 20 carburetor
Old 10-14-2013 | 05:02 PM
Default DLE 20 carburetor
Hello this is my first time here I got a question I have a dle 20 engine and it is giving me some problemswith the carburetor I was trying to buy a new carburetor but it is out of stock my question is:Can I use a DLE 30 carburetor in a DLE 20 engine?the reason I ask is because DLE 30 carburetor is available at the store and they are about the same from outside I will preciate your help thank you very much in advance have a good night my name is Karel.
Old 10-14-2013 | 06:09 PM
My Feedback: (19)
While they are very similar, the 20 has a much smaller venturi that many consider oversize as is. Where all have you looked for a carb? Can't believe all are out of stock. How about something like a Valley View 20 carb? Bolt on replacement and a genuine Walbro if you care about that.
Old 10-14-2013 | 07:07 PM
thank you for your answer I'm new with this gas engine if you know any other carb that could be a replace sound good to me can you tell me exactly name or number to look for it thanks
Old 10-14-2013 | 07:14 PM
Sir I I just found it at Valley view Rc you saved my life thank you very much I'm going to buy that one
Old 10-14-2013 | 08:20 PM
My Feedback: (19)
Good deal! I thought Valley View would have one in stock.
Old 10-15-2013 | 01:54 AM
Lifer's Avatar
The answer to your original question is yes, you can bolt the 30cc carb to the 20cc engine. Expect about a 500, plus rpm gain.
Old 10-17-2013 | 10:20 AM
raptureboy's Avatar
Why are you buying a new carb would be my question. Very few carbs just go bad. What are the issues you are having?
Old 10-19-2013 | 01:41 AM
thank you guys for your help I just received yesterday the new carb and install it so I haven't tried yet I will try it tomorrow Sunday to see if the problem is solved
Old 10-19-2013 | 03:13 PM
My Feedback: (19)
And as raptureboy requested, what problems were you having with the original carb? Just curious.
Old 10-19-2013 | 05:10 PM
Same here. most problems can be fixed with out replacing the carb.
