dle 20 gas engine
Old 10-18-2013 | 08:42 PM
top gun reed's Avatar
Default dle 20 gas engine
hey fellows I was needing to no if anyone can tell me if they have ran a 17/8 prop on this engine and would it be a good ideal to run this prop on my 60 size p-40war hawk by top flite thank,s
Old 10-19-2013 | 02:17 AM
Lifer's Avatar
APC sells a 17x8N prop that will work fine on your DLE.
Old 10-23-2013 | 08:05 AM
kmeyers's Avatar
One hundred owners serveyed: 49 using 16x8
............................................. .....48 using 17x6
What is the point of your question? use a 16x8 or 17x6 proven results.
Old 10-23-2013 | 08:12 AM
w8ye's Avatar
My Feedback: (16)
+1 on the 16 X 8 or 17 X 6
Old 10-23-2013 | 09:14 AM
grosbeak's Avatar
I used a 16 x 8, mostly, until I switched to a 15 x 7 3-blade.
Old 10-23-2013 | 12:56 PM
kmeyers's Avatar
grosbeak
This information should include reasons ie ground clearance etc. and performance changes. Did you get better performance less the same. I've been thinking of trying a three blade.
please give a little more info.
Old 10-23-2013 | 01:20 PM
Seems like I have to agree with most of the other opinions. I have and will continue to use a 16 x 8 prop on my 20cc engines. But then again, I may change manufacturers, wood, carbon fiber, etc. Guess, its just what I feel that I should be using while assembling the model.
